Browse Forums Heating, Cooling & Insulation Re: Opinion hydronic slab heating with engineered floorboard 7Oct 15, 2017 4:24 pm mboy Thanks very much. How effective did you find the heating through wood in terms of keeping the house warm? There are these new engineered boards where the base is made of stone and meant to conduct heat as close enough to tiles? and I wonder how they compare to other engineered boards that have wood on either side of the ply. Hi mboy, these stone based engineered boards sound intriguing. I googled them (heatboard) but couldn't find a price. Any idea how the cost compares to normal engineered boards? Re: Opinion hydronic slab heating with engineered floorboard 8Oct 15, 2017 6:37 pm Good timing - Ive been asking around! Heatwood: reconstituted stone based with 3-4mm wood board lining : ~ $150 per m2 (240mm wide) The other one is Mafi: you get wood on both sides with ply in the middle $170 per m2 (235mm wide).. I believe having wood on both sides makes everything 'more evenly' distributed and you get more wood! Both products looks fantastic. You get a loss less wood with Mafi, but it make sense to have the poor conductive properties of wood kept to a minimum to be similar to tiles/polished concrete. The limited experience I can find about hydronic slab heating with wood seems to be so variable, and I guess there are so many variables with the products and installation. Unfortunately I cant find any personal experience to gauge which would be better. Re: Opinion hydronic slab heating with engineered floorboard 9Oct 17, 2017 6:50 pm Hmm... Hardwood engineered floors supply are generally below $100/per sqm, you can find some options for $60/per sqm. Although hardwood is not the worst insulator, as long as it not very thick (e.g. below 15 mm) - it should be doing okay, as any insulator - just delaying the heat transfer, but once heated - it should be fine. Re: Opinion hydronic slab heating with engineered floorboard 10Oct 18, 2017 8:26 pm I think another challenge is whether the builder is happy to install this on their slab and insure for it as part of warranty. I think its not very common to do hydronic slab engineered board heating, and some builders have no experience in this. They are more comfortable with panels or polished concrete/tile. Thats another challenge! Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 5089 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 5000 Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6266 |
