Yup we couldn't be happier, we were living like savages in a dumpster!!!!!! hahaha
Browse Forums Building A New House KDR Metricon Liberty - Hampshire 45 QLD 1610Oct 03, 2017 1:22 pm dulie DRT This looks amazing. Do you mind sharing the rough costs for all of it as i was planning on getting M to do a laundry fitout and just for basic top and bottom cupboard the are charging around $1500. Thanks Hi DRT, I've actually had this conversation with Renman before (both building hampshire, so same size laundry), and to our surprise M was actually cheaper. It's strange cause every single other item with M has been much more expensive. From memory Renman with M cost $3500ish. Me doing post cost $4500ish. Neither cost include splash back. Guys, I think M has caught on to this and have started to charge around the $5000-$5400 price range for something very similar to what I got. Dulie, great planning to fit the laundry sink in the correct place. Haha It was also one of our concerns at the start. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: KDR Metricon Liberty - Hampshire 45 QLD 1611Oct 03, 2017 6:44 pm Dulie the Laundry looks great. To good to use! You might need a 'Butler's Laundry' to do the washing! Re: KDR Metricon Liberty - Hampshire 45 QLD 1612Oct 04, 2017 6:52 am Laundry looks great Dulie! I like how you’ve also got tiling next to the laundry door to the outside as well Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: KDR Metricon Liberty - Hampshire 45 QLD 1613Oct 04, 2017 7:06 am What a gorgeous laundry! I should have put more thought into ours. I must have missed something along the way but did you get it done through M or privately post handover. Considering doing something similar even though ours is a third of your size. Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: KDR Metricon Liberty - Hampshire 45 QLD 1614Oct 04, 2017 11:09 am stanus Dulie the Laundry looks great. To good to use! You might need a 'Butler's Laundry' to do the washing! hahaha never thought of that! Gonna have to save that one for next house lol. Quirmeball1280 Laundry looks great Dulie! I like how you’ve also got tiling next to the laundry door to the outside as well I"m glad you like it! I did the tiling myself with left over tiles from M hehehe. =D Corallake What a gorgeous laundry! I should have put more thought into ours. I must have missed something along the way but did you get it done through M or privately post handover. Considering doing something similar even though ours is a third of your size. Thanks CL. I got the laundry done privately post hand over. Definitively super easy to get done later. Re: KDR Metricon Liberty - Hampshire 45 QLD 1615Oct 04, 2017 8:48 pm We been told by our electrical consultant if there is no windows for the toilets then exhaust fan and light must be in one switch and can not have separate switches. we really wanted separate switches. Is this the case for every one? Re: KDR Metricon Liberty - Hampshire 45 QLD 1616Oct 04, 2017 9:38 pm Kandi We been told by our electrical consultant if there is no windows for the toilets then exhaust fan and light must be in one switch and can not have separate switches. we really wanted separate switches. Is this the case for every one? That’s is correct. I am sure you can change it post. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: KDR Metricon Liberty - Hampshire 45 QLD 1617Oct 04, 2017 9:59 pm Yup it's the same at my house. I was super against it in the beginning, but now i'm kinda glad they are on the same switch. Cause in our ensuite they are on separate switches, and lots of the time i forget to turn on the fan. Re: KDR Metricon Liberty - Hampshire 45 QLD 1618Oct 05, 2017 6:38 am Kandi We been told by our electrical consultant if there is no windows for the toilets then exhaust fan and light must be in one switch and can not have separate switches. we really wanted separate switches. Is this the case for every one? We managed to get around this. We have lights connected to a sensor and only the manual 'on ' switch triggers the fan. So you can walk in and just trip the sensor for the light and no fan unless you press the switch. M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: KDR Metricon Liberty - Hampshire 45 QLD 1619Oct 05, 2017 7:47 am Kandi We been told by our electrical consultant if there is no windows for the toilets then exhaust fan and light must be in one switch and can not have separate switches. we really wanted separate switches. Is this the case for every one? Ours have separate switches Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR Metricon Liberty - Hampshire 45 QLD 1620Oct 05, 2017 9:21 am Kandi We been told by our electrical consultant if there is no windows for the toilets then exhaust fan and light must be in one switch and can not have separate switches. we really wanted separate switches. Is this the case for every one? We have the same arrangement in our powder room, which does not have an external window. Frankly, i think that's fine. As Dulie mentioned, in our en-suite we have separate switches, and i almost always forget to turn on the exhaust fan. dulie, love how your laundry has shaped up. Looks awesome! Great job with the DIY tiling too! We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37363 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 19245 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 13569 |
