Browse Forums Building A New House Re: Should my plumbing look like this? 3Oct 01, 2017 1:31 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Should my plumbing look like this? 4Oct 01, 2017 1:33 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Should my plumbing look like this? 7Oct 01, 2017 1:59 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Should my plumbing look like this? 8Oct 02, 2017 6:34 am The pipes are in the cavity therefore on outside of the stud wall. It is unlikely that any fixing of shelving will go right through stud and puncture a pipe. Yes piping could have been a bit neater but at least it is clipped to studs. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Should my plumbing look like this? 9Oct 02, 2017 11:12 am If what your worried about is the pipe not running dead straight then be assured that most Flexi pipe is installed like that with curves and sweeping bends. To me, yours look neat. The outdoor thing is new to me as I'd generally seen them in the roof and hollow internal walls. Your more likely to hit the pipe if drilling completely through the bricks from the outside and manage to punch through the hole brick. The pipes are low but if you're ever wall mounting a clothes line or hose reel just be mindful of their location and the drilling depth. No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 12034 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6372 Hi Sillysausage1900, Hope all is well. I came across this forum as Im somewhat same situation with you regarding Roof Plumbing certificate requirement. Im requesting a… 4 9510 |
