Browse Forums Safer Living Re: Wireless vs Wired home alarms? 4Jun 30, 2017 10:54 am Data Cabling and Security Service - www.leact.com.au 0488 033 022 Data Cabling NBN MDF Jumper IT Network Alarm CCTV Access Control Intercom Re: Wireless vs Wired home alarms? 6Sep 27, 2017 8:48 am Hardwired is always better No batteries to change, no range issues Use a security installer not an electrician, security installers need to be licensed in most states, so check as each state has its own requirements. Re: Wireless vs Wired home alarms? 7Apr 15, 2020 5:01 pm A wireless home alarm system is best. No need for drilling holes or making other modifications. But make sure to choose high-quality security gear. Re: Wireless vs Wired home alarms? 8Apr 16, 2020 8:02 pm I think wired is best too because then you don't have to worry about changing batteries etc. I do agree that get a professional security company to have a look at the placement of the detectors. I initially suggested a few locations which I think is suitable but the professional changed it and explained to me. All are great reason. Re: Wireless vs Wired home alarms? 9Jun 09, 2020 3:49 pm wired too:-D Data Cabling and Security Service - www.leact.com.au 0488 033 022 Data Cabling NBN MDF Jumper IT Network Alarm CCTV Access Control Intercom Re: Wireless vs Wired home alarms? 10Apr 28, 2021 8:45 am I can only speak on Bosch alarms, but in general wireless and wired are good the only problem with wireless are they require batteries of cause and they go into a 3 minute sleep cycle after being triggered once even if the alarm is not armed. If you can get it pre-wired it will be better for future reasons encase you upgrades that don't support wireless. TRANTECH SECURITY WHOLESALER 26 Davies Ave, Sunshine North VIC 3020 T: (02) 8722 0348 (Syd) T: (03) 9079 5566 (Mel) www.trantechsecurity.com.au Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5899 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16553 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110801 |
