Browse Forums Building A New House Re: Building 2 storey with APG Homes in WA – Our build threa 22Jul 24, 2017 11:18 am Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Re: Building 2 storey with APG Homes in WA – Our build threa 23Jul 30, 2017 10:01 pm Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Re: Building 2 storey with APG Homes in WA – Our build threa 24Aug 27, 2017 9:02 pm Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Re: Building 2 storey with APG Homes in WA – Our build threa 25Aug 27, 2017 11:19 pm Follow our build with Express Two Storey (Ventura Group): viewtopic.php?f=31&t=85122 Re: Building 2 storey with APG Homes in WA – Our build threa 26Sep 03, 2017 10:22 am Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Re: Building 2 storey with APG Homes in WA – Our build threa 27Sep 18, 2017 1:16 pm So we didn't get out to our site last weekend so we were pretty excited to see how much progress has been made over the last fortnight. The roof carpenters have been and put up most of the roof frame on the second storey. I've been thinking about solar electricity lately. We hadn't considered it (or thought about it) prior to now, but it would make sense that seeing as we plan on living in the house a while, that we might want to put it in at some point. I have no idea how hard it is to install in a 2 storey house after handover, so we've got APG sussing it out for us now (in case they need to put conduits or a pre-wire in for us). Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Re: Building 2 storey with APG Homes in WA – Our build threa 28Oct 01, 2017 10:51 am Another fortnight of steaming through the build! The few days of miserable weather didn't stop progress! Electrical and plumbing is mostly completed to the top storey, as well as all the smart wiring. Bits and pieces have been run to the bottom storey, but I suspect they are waiting until the roof cover is on the ground floor before doing too much. One thing I did find interesting is that even on the cavity walls on the second storey, the electrical wires have been cut into the bricks (rather than being run down the cavity). On the ground floor they are run through the cavity, no idea why it's not the case on the second storey? I'll speak to the site supervisor about it when he calls for his fortnightly update next week. Landing on the upper storey: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master bedroom ensuite: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The wiring from the smart wiring panel on the second storey, through to all the points under the suspended slab. Far right is where the water feeds into the wet areas upstairs. This hole fits under the peak of the ground floor rooft Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master bedroom Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It's starting to look like home! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Re: Building 2 storey with APG Homes in WA – Our build threa 29Oct 01, 2017 11:35 am danbiscuit Thanks for the photos I suggest you take a few more and check the engineering Roof beams plans over the stairs as there is lot going on up there? Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building 2 storey with APG Homes in WA – Our build threa 30Oct 01, 2017 12:12 pm StructuralBIMGuy @danbiscuit Thanks for the photos I suggest you take a few more and check the engineering Roof beams plans over the stairs as there is lot going on up there? G'day, thanks for replying. I've got the following photos from that area. We did ask the builder to ensure there was an appropriate beam to hang a pendant light down from in the future.What are your thoughts?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Re: Building 2 storey with APG Homes in WA – Our build threa 31Oct 01, 2017 6:24 pm Danbiscuit Unfortunately the photos aren't that clear over the stairs There appears to be a counter beam of some sorts with struttings (LHS/Middle) ? Check your engineering drawing and the connections BTW it's for you own benefit that you take proper photos etc,etc You only have to put them up if there are queries hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building 2 storey with APG Homes in WA – Our build threa 32Oct 04, 2017 9:39 am G'day, thanks for highlighting it! I live quite far from our site at the moment, so I'll check it out this weekend and take a few more photos Dan Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Re: Building 2 storey with APG Homes in WA – Our build threa 33Oct 07, 2017 8:57 am danbiscuit Another fortnight of steaming through the build! The few days of miserable weather didn't stop progress! Electrical and plumbing is mostly completed to the top storey, as well as all the smart wiring. Bits and pieces have been run to the bottom storey, but I suspect they are waiting until the roof cover is on the ground floor before doing too much. One thing I did find interesting is that even on the cavity walls on the second storey, the electrical wires have been cut into the bricks (rather than being run down the cavity). On the ground floor they are run through the cavity, no idea why it's not the case on the second storey? I'll speak to the site supervisor about it when he calls for his fortnightly update next week. Landing on the upper storey: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master bedroom ensuite: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The wiring from the smart wiring panel on the second storey, through to all the points under the suspended slab. Far right is where the water feeds into the wet areas upstairs. This hole fits under the peak of the ground floor rooft Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Master bedroom Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ It's starting to look like home! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi danbiscuit Looking great, Could be flashing in the walls/cavity, to get down the cavity to where your GPO's are (300mm),then they may have had to penetrate through this. Which is not good, hence why they have chased the cavity walls. _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Building 2 storey with APG Homes in WA – Our build threa 34Oct 07, 2017 9:02 am danbiscuit StructuralBIMGuy @danbiscuit Thanks for the photos I suggest you take a few more and check the engineering Roof beams plans over the stairs as there is lot going on up there? G'day, thanks for replying. I've got the following photos from that area. We did ask the builder to ensure there was an appropriate beam to hang a pendant light down from in the future.What are your thoughts?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi danbiscuit, In regards to the future pendant light, most cases it will attach the the ceiling joists, obviously depending on how heavy the light is which would be determined once onsite, an electrician can always install and extra support once the ceiling is up. Similar to installing a ceiling fan if there was an existing light point before! _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Building 2 storey with APG Homes in WA – Our build threa 35Oct 07, 2017 10:10 am Hi danbiscuit Sorry to bombard you, In regards to solar you could install the inverter inside the store area of the garage, or if you like they can always install it adjacent to the meter box, as they are weather protected. I would install it inside personally! To think about for ease of installation at later stage: Cable from switchboard to inverter location (2.5mm - 4mm Twin+E) up and over to garage/store As there is a small roof space to the right side of your garage the installers will more than likely be able to install the DC side to there. Failing that I believe the installation can be done at a later stage if it was installed near the meterbox _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Building 2 storey with APG Homes in WA – Our build threa 36Oct 08, 2017 9:30 am G'day Sparky, thanks for your replies! I spoke to our site supervisor about not running the cables through the cavity walls, and he said they generally always cut them into the walls with both internal and external walls. I asked him whether I would be able to use the cavity in the future (as I'll probably want to get some extra data points upstairs after handover), and he said there was no issues using the cavity. Interesting that you mention the flashing, I've taken heaps of photos of all stages of the build, and I have noticed lots of flashing where the upper and ground roofs will intersect, I haven't noticed anywhere I would potentially want to be adding data points at a later date. I took this photo above the stairs: not sure if it all looks legit? Maybe there are so many beams to give us flexibility when we put our downlight in?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I ended up getting APG to run the solar pre-wire, it just seems easier that way.. They are just confirming the location of the wires in the garage now, I have asked them to run it to a little nook on the left hand side of the garage, so the inverter is out of the way. I'll have a lot of shelving in the store area so I don't want to have the inverter there. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Re: Building 2 storey with APG Homes in WA – Our build threa 37Oct 08, 2017 9:35 am This week there's been heaps of progress, although not as noticeable as the past few months. More of the electrical, data, and security cabling has been run on the upper storey. The air conditioning ducts have been run through the upper storey, and the corner beads have been put on the upper storey corners... Hopefully, that means the internal cement render is imminent? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Re: Building 2 storey with APG Homes in WA – Our build threa 38Oct 08, 2017 9:49 am danbiscuit Thanks for the update I suggest you get the Counter beam & Connections checked & certified by an engineer in writing , first check your engineering beam drawings/details and then have the revised Structure certified as equivalent/ or better than what's required in the codes (min.). if you require assistance please leave a PM Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building 2 storey with APG Homes in WA – Our build threa 39Oct 08, 2017 10:03 am Hi danbiscuit Yeah that is a good location I agree! Is the GPO on the plan you have circled a separate circuit from the switchboard? just check this, as it appears to be a standard GPO at a certain height symbol. Needs to be a dedicated circuit for the inverter. Also check if there is a separate conduit installed into the slab for the solar installers to get the DC side to the inverter. I can see there will be roof space at the front of the house hopefully they can install the DC to the garage that way if no conduit has been installed. Have you got an electrical plan that you can upload? _____________________________________ Building in Bedfordale Perth WA https://forum.homeone.com.au/viewtopic.php?f=31&t=89716 Churchman Brook Electrical Services EC 8659 Re: Building 2 storey with APG Homes in WA – Our build threa 40Oct 08, 2017 11:19 am StructuralBIMGuy @danbiscuit Thanks for the update I suggest you get the Counter beam & Connections checked & certified by an engineer in writing , first check your engineering beam drawings/details and then have the revised Structure certified as equivalent/ or better than what's required in the codes (min.). if you require assistance please leave a PM I'll chase it up with the builder this week. We actually haven't been provided any engineering drawings (the steel beams to support the upper slab are marked on the drawings but nothing to do with the roof timber, beyond the fall direction of the roof). I'll let you know what the say Thanks again Building in Gwelup (WA) with APG Homes: https://forum.homeone.com.au/viewtopic.php?f=31&t=88108 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8179 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 11109 Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9616 |
