Ok, so you wouldn't believe this but our pole to pit application has been processed and we have a quote --- $4300
Browse Forums Building A New House Re: Porter Davis - Madison 40 141Sep 11, 2017 8:30 pm Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Porter Davis - Madison 40 144Sep 11, 2017 10:01 pm Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Porter Davis - Madison 40 147Sep 14, 2017 12:15 am Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Porter Davis - Madison 40 148Sep 14, 2017 12:18 am Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Porter Davis - Madison 40 150Sep 15, 2017 8:44 pm Building a Madison 45 with Porter Davis Madison 45 Blog (Send me a PM with your email address to be added) Re: Porter Davis - Madison 40 153Sep 17, 2017 2:28 pm Gio How is everyone else going with their Madison build? Hope all is well. Here is the latest pics. Option 5 Stairs - Landing will be done after Handover as it is a custom build job for Madison40. I couldn't get a quote on it at WoS. They only had quote for Madison45 landing. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ External: Final coat render on ground floor happening next week. Should be same as upstairs. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Sideview Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looks fantastic! - View my blog at www.waldorfgrangebuild.wordpress.com Re: Porter Davis - Madison 40 154Sep 17, 2017 6:12 pm Gio ISSUE WITH MY PANTRY/GALLEY WINDOW. Ok peeps, earlier during the build it was brought to my attention that the window in the pantry in the Madison is lower than what is on the drawing. When it comes to windows, builder/carpenters work off the external elevation when they do the frame. On the elevation drawing it says 900mm from slab At tender we decided to have a square set window with tiles all around. So when you look at it, you see the benchtop > tiles > window > tiles and the overhead cupboard. As per the Pic below Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The issue with mine was, I did not have the space to do the tiling between the top of the bench and the bottom of the window. The window would sit flush with the benchtop, which still looks nice but it will leave too much of a gap to tile on top and that would look a bit weird to have a lot of space between the top of the window and the cupboard. If I had a bigger window It would have been fine. I don't mind the window flush with the benchtop. It looks nice. Most displays have it flush with the benchtop. I just couldnt get a bigger window (was too late) as it would have to be custom built. And at this point in the construction it was too late anyway. So to fix this, they had to cut the hebel externally, re-adjust the frame, raise the window and patch again with hebel and plaster inside. Key take if you have tiles around your galley window: If you are tiling around your galley window no matter which house you build, just ENSURE that the frame is CORRECT. Also ENSURE that all Windows in the house DOWNSTAIRS and UPSTAIRS and especially in Bathrooms that the window doesn't sit too low. I have already provided this feedback to my BC and to pass it on to the drafting team so that this is not overlooked when they do the drawing. Just make sure you carefully look at yours if you plan to have tiles around your galley window. Hi Gio, do you have before/after pictures that you can share? I think this may be something I may need to sort out with my build as we also have a similar situation with our Kitchen window in addition to the galley... Re: Porter Davis - Madison 40 155Sep 17, 2017 6:51 pm sinbox Gio ISSUE WITH MY PANTRY/GALLEY WINDOW. Ok peeps, earlier during the build it was brought to my attention that the window in the pantry in the Madison is lower than what is on the drawing. When it comes to windows, builder/carpenters work off the external elevation when they do the frame. On the elevation drawing it says 900mm from slab At tender we decided to have a square set window with tiles all around. So when you look at it, you see the benchtop > tiles > window > tiles and the overhead cupboard. As per the Pic below Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The issue with mine was, I did not have the space to do the tiling between the top of the bench and the bottom of the window. The window would sit flush with the benchtop, which still looks nice but it will leave too much of a gap to tile on top and that would look a bit weird to have a lot of space between the top of the window and the cupboard. If I had a bigger window It would have been fine. I don't mind the window flush with the benchtop. It looks nice. Most displays have it flush with the benchtop. I just couldnt get a bigger window (was too late) as it would have to be custom built. And at this point in the construction it was too late anyway. So to fix this, they had to cut the hebel externally, re-adjust the frame, raise the window and patch again with hebel and plaster inside. Key take if you have tiles around your galley window: If you are tiling around your galley window no matter which house you build, just ENSURE that the frame is CORRECT. Also ENSURE that all Windows in the house DOWNSTAIRS and UPSTAIRS and especially in Bathrooms that the window doesn't sit too low. I have already provided this feedback to my BC and to pass it on to the drafting team so that this is not overlooked when they do the drawing. Just make sure you carefully look at yours if you plan to have tiles around your galley window. Hi Gio, do you have before/after pictures that you can share? I think this may be something I may need to sort out with my build as we also have a similar situation with our Kitchen window in addition to the galley... Re: Porter Davis - Madison 40 156Sep 17, 2017 7:31 pm brucefil2011 sinbox Gio ISSUE WITH MY PANTRY/GALLEY WINDOW. Ok peeps, earlier during the build it was brought to my attention that the window in the pantry in the Madison is lower than what is on the drawing. When it comes to windows, builder/carpenters work off the external elevation when they do the frame. On the elevation drawing it says 900mm from slab At tender we decided to have a square set window with tiles all around. So when you look at it, you see the benchtop > tiles > window > tiles and the overhead cupboard. As per the Pic below Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The issue with mine was, I did not have the space to do the tiling between the top of the bench and the bottom of the window. The window would sit flush with the benchtop, which still looks nice but it will leave too much of a gap to tile on top and that would look a bit weird to have a lot of space between the top of the window and the cupboard. If I had a bigger window It would have been fine. I don't mind the window flush with the benchtop. It looks nice. Most displays have it flush with the benchtop. I just couldnt get a bigger window (was too late) as it would have to be custom built. And at this point in the construction it was too late anyway. So to fix this, they had to cut the hebel externally, re-adjust the frame, raise the window and patch again with hebel and plaster inside. Key take if you have tiles around your galley window: If you are tiling around your galley window no matter which house you build, just ENSURE that the frame is CORRECT. Also ENSURE that all Windows in the house DOWNSTAIRS and UPSTAIRS and especially in Bathrooms that the window doesn't sit too low. I have already provided this feedback to my BC and to pass it on to the drafting team so that this is not overlooked when they do the drawing. Just make sure you carefully look at yours if you plan to have tiles around your galley window. Hi Gio, do you have before/after pictures that you can share? I think this may be something I may need to sort out with my build as we also have a similar situation with our Kitchen window in addition to the galley... Did PD charge you anything extra for that finish? The above picture is exactly what I had in mind, and was assured that the finish would be the same as in the display Homes. Re: Porter Davis - Madison 40 157Sep 17, 2017 7:36 pm sinbox brucefil2011 sinbox [quote="Gio"]ISSUE WITH MY PANTRY/GALLEY WINDOW. Ok peeps, earlier during the build it was brought to my attention that the window in the pantry in the Madison is lower than what is on the drawing. When it comes to windows, builder/carpenters work off the external elevation when they do the frame. On the elevation drawing it says 900mm from slab At tender we decided to have a square set window with tiles all around. So when you look at it, you see the benchtop > tiles > window > tiles and the overhead cupboard. As per the Pic below Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The issue with mine was, I did not have the space to do the tiling between the top of the bench and the bottom of the window. The window would sit flush with the benchtop, which still looks nice but it will leave too much of a gap to tile on top and that would look a bit weird to have a lot of space between the top of the window and the cupboard. If I had a bigger window It would have been fine. I don't mind the window flush with the benchtop. It looks nice. Most displays have it flush with the benchtop. I just couldnt get a bigger window (was too late) as it would have to be custom built. And at this point in the construction it was too late anyway. So to fix this, they had to cut the hebel externally, re-adjust the frame, raise the window and patch again with hebel and plaster inside. Key take if you have tiles around your galley window: If you are tiling around your galley window no matter which house you build, just ENSURE that the frame is CORRECT. Also ENSURE that all Windows in the house DOWNSTAIRS and UPSTAIRS and especially in Bathrooms that the window doesn't sit too low. I have already provided this feedback to my BC and to pass it on to the drafting team so that this is not overlooked when they do the drawing. Just make sure you carefully look at yours if you plan to have tiles around your galley window. Hi Gio, do you have before/after pictures that you can share? I think this may be something I may need to sort out with my build as we also have a similar situation with our Kitchen window in addition to the galley... Did PD charge you anything extra for that finish? The above picture is exactly what I had in mind, and was assured that the finish would be the same as in the display Homes. [/quote]we had to pay extra for the square set window as it was larger than std, it wasnt much though. we also needed to pay about $100 so the bench extends back to the window. the photo is from the PD display home the hoffman in Eastern Melbourne Re: Porter Davis - Madison 40 158Sep 21, 2017 10:02 pm We have just signed up for a Madison 40 - have a tentative start date of February 2018 - woohoo, very exciting. Reading this blog has been awesome. We have a consultant appointment coming up next week. Our plans are coming together, we have moved the master bed to the front, ensuite to bed 2 and added a guest bedroom. Will upload plans after our consultant appt. I am hoping that the pluming stack will go from dining as there are no wet areas in that part of the house any more. What are the biggest things you have learnt in the process that you wished you knew at the beginning? Michael Re: Porter Davis - Madison 40 159Sep 22, 2017 5:48 pm MikW Awesome another Madison home builder. Welcome mate. We also swapped the bed to front but didn't go for the bed 2 ensuite or guest bed downstairs. Instead of the guest bed, we kept it as the living room and added in a fireplace. As far as structural change, just front bed swap, garage extension and alfresco extension. Fixing just completed. Now only painting, door handle fittings, electrical fittings, tiling and flooring left. This is my second build with PD but my fourth in total. There are a lot of things you might want to consider such as: > high ceiling downstairs and upstairs, > 450mm eaves around the house > bigger garage perhaps or 3 garage, > Fixed picture windows perhaps > Square set in master ens may be > think also about access to property, you might want to center the house on the block or keep it on the left leaving enough space for a gate on the right side..etc.. If you browse through the Madison threads or other PD threads you will get a lot of info. Any concern or questions post them in the Madison thread. Cheers Building the Madison 40 | By Porter Davis Re: Porter Davis - Madison 40 160Sep 22, 2017 9:10 pm Waldorf_Grange_Build Madison40builder Another question, are you hiring an independent inspector? I'm looking at using Darbecca. Our PD sales consultant gave us the big spiel that we are wasting our money etc etc as they hire one on our behalf. I'm like, thanks but I think for such a huge investment we will hire our own. When I spoke to Darbecca she said that they work on behalf of PD clients regularly. K We are using Darbecca and I would highly recommend them. They found 8 defects with our slab so far. Their fee is a small price to pay when you compare it to the value of your home. Have you used Darbecca for every stage as outlined in their quote or just some selected ones? Their cost adds up a bit, but I am sure that they more than pay for themselves in seeing things that a non-builder would just miss and end up having to live with? Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 14039 |
