Browse Forums Building Standards; Getting It Right! Re: Is this Pre-lay out? 8Sep 09, 2017 11:47 am 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Is this Pre-lay out? 9Sep 11, 2017 10:18 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Is this Pre-lay out? 11Sep 11, 2017 8:38 pm Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Is this Pre-lay out? 12Sep 11, 2017 10:20 pm StructuralBIMGuy @akash19p No, I meant did you take photos of the trenches & reinforcement mesh before the concrete was poured? Soil type?, Dimensions, How close is it a internal longitudinal stiffeners? etc All these factor will influence potential cracking... Sorry they will do it this week and it's under the kitchen island banch ... They said they will put a rod to support the drainage pipe and put all the mash and required material before the pour the concrete . Solid is A class .. Flat bock ... The land used to be old market garden... Will send you the pics as soon as they do the work .. Thanks for the guideline ... Re: Is this Pre-lay out? 13Feb 04, 2018 4:22 pm To be honest that slab doesn't look right to that drawing, because part of that sand should be a hallway to your front door beside bedroom 1 and the garage. The plumbing looks right if you take into account where the bath and toilet plumbing is, the slab doesn't look right from that pic. We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13744 The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8702 Just to makea point about this, an approach that some people have found sucessful in negotiating these rises down, Is to provide some workings to the builder, specifying… 4 81667 |
