Browse Forums Flooring & Floor Covering Re: Laminate Timber Floor Experiences??? 5Sep 08, 2017 10:31 pm Hey! We have had laminate floor for about 7 years. It's very hardy, only dent we have (and it's small) husband sat on a child's chair with our then two year old son on lap. It collapsed and a screw under the chair put a dent. See very extreme situation. We have decided on laminate again. With kids and pets it's the best option for us! It's a wide board blackbutt laminate from Carpet Court. Good variances in boards and we think it looks good. Good luck with what you decide. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Laminate Timber Floor Experiences??? 6Jun 03, 2018 2:29 pm alexp79 what about engineered hardwood, e.g. oak? should be a good fit for your bedrooms. laminate is just a plastic with "printed" wood on it. bamboos are good, but a bit on a hard side, oak is much softer. Laminate is not plastic, you may have confused with something else. Re: Laminate Timber Floor Experiences??? 7Jun 11, 2018 11:12 am We are looking at our flooring options too at the moment and will hopefully go for engineered timber which is a more cost effective solution than actual timber boards. Otherwise we are considering laminate as that comes included in our package. However speaking to Harvey Norman, we were told laminate is actually not water proof if it buckles or any of the joints let water in. Only the top surface is water proof. Another thing to consider is scotia beading with laminate floors which also goes around kitchen bench. I recommend you find a display home with laminate flooring and take a look at that. Our builder will eliminate scotia beading if we leave the kitchen kickboards off and someone comes in later to install them and also go for wider skirting boards rather than standard, you can get rid of requiring beading. Good luck. You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18065 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15918 The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring… 1 3279 |
