Browse Forums Renovation + Home Improvement 1 Sep 08, 2017 3:46 pm Hi everyone In case there were a similar situation you knew or saw, The rumpus was garage before converted in 70s, conrete slab, brick veneer wall. Noted a back corner sinking several years ago when moved in, and a big tree was removed around that time with stumps grindered. That corner side seems sinking each year and now the front corner in the same side now have 1 cm gap. Recently tried to get into craw space and noted some water sitting same side, where then identified a downsprout blocked by leaves below ground. The position is about 2 to 3 meters to the sunken corner as mentioned above. Got a plumber to clean out the storm drains and replaced broken part near front and most likely by tree root. It all happens in the same side! I am thinking what would be reasonable or good to level indoor slab, and Who to engage i.e. a civil engineer first, and timing , let moisture gone say after summer to repair? Any experience or recommendation ? Thanks Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9611 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17191 |
