Browse Forums Kitchen Corner Re: To Handle or Not Handle???? 4Sep 04, 2017 12:21 pm For me it really depends on a few things, The size of the kitchen and the amount of storage you need The type of handless kitchen you want, Sharknose or Push to Open. If you kitchen is on the smaller side and you have a lot of drawers I would suggest that sharknose isn't the way to go. With a normal set of drawers with sharknose it becomes almost impossible to double stack pots. For every drawer you loose 50mm in height with sharknose. My preference is a nice handle below bench and handle less above bench. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: To Handle or Not Handle???? 5Sep 04, 2017 12:21 pm bank We went no handles on overhead cupboards for the cleaner line, and handles for lower. We have mostly drawers and I didn't want to lose the internal height that you do with no handles. Not as much of an issue if you have two large drawers but i wanted 1 small, two larger in each stack. I totally agree! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6349 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9074 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6176 |
