Browse Forums Building Standards; Getting It Right! Re: building inspection report 3Aug 19, 2017 9:26 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: building inspection report 5Aug 28, 2017 4:44 am Ask your building inspector these questions If you are in Vic- Call the building surveyor or have your inspector do this if builder is ignoring you. Good luck and keep at it. Running over contract is exhausting but better to have it right for long term gain. Re: building inspection report 6Aug 28, 2017 4:41 pm Mars5 If you are in Vic- Call the building surveyor or have your inspector do this if builder is ignoring you. This is correct. In Victoria, the surveyor is now required to be employed by the home owner, not the builder. Make sure that he is doing his job. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5414 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98772 Hi, I have this sewer inspection point sitting in an odd spot in the rear of my yard: https://imgur.com/ghLI98q What I'd like to do is put a firepit in that corner of… 0 6619 |
