Browse Forums Building A New House Re: Stockland Elara at Marsden Park 2550Aug 21, 2017 3:52 pm Hello Elarians... My land is due to register in Feb 18 so I have started to look around for builders. Is anyone able to provide any feedback on elderton or coral homes. As per my research there are plenty of negatives reviews on delays with elderton. With coral homes I couldn't find much on building in sydney region as I most of their business generate from qld. I will appreciate any feedback on either of them based on your experience. Re: Stockland Elara at Marsden Park 2551Aug 22, 2017 10:24 am Ausman yourpalcliffy Is it mandatory to render the piers and porch area? I do not see any such requirement in the design guidelines. My builder says its a developer requirement. Could someone please confirm? Thanks in advance. Rendering is not Mandatory but is one of the options, you can also go with Moroka Paint (cheaper than rendering). If you see on Elara blvd there is a mixture of Render and Moroka paint on the front facade of the houses. Thanks Ausman could you please confirm if we need to paint/render the porch walls also or it is the requirement just for the piers? Re: Stockland Elara at Marsden Park 2552Aug 22, 2017 10:59 am AlDob phanee.gbm Wondering if there is a need of Double glazed windows/doors for Marsden park!!! Can we survive with normal glazing? This winter we feel much better with gas fireplace rather than double glazing I have one mate. He has a triple glazing however in a morning inside his house temperature just only one degree higher then in ours. We use our fireplace every evening and a bill surprisingly wasn't that high Thank you. Re: Stockland Elara at Marsden Park 2553Aug 24, 2017 10:21 am Hi All Could anyone please help to get estimate costs for corner lot fencing. I am in stage 23 and haven't yet started construction but trying to figure out total costs for the build. From what i understand Stockland wants to have brick piers between every 2 panels of colourbond fence. I saw the guidelines for frontier lots and that's what it states. Really appreciate if someone could help me. Dimensions of my lot are 15x28m. Its a corner lot so i don't share any costs with my neighbours for street facing fence. Thanks Re: Stockland Elara at Marsden Park 2554Aug 24, 2017 3:31 pm How much time Sydney-Water takes for approval? My builder has applied for it 2 weeks back, but no update so far. Thanks. Re: Stockland Elara at Marsden Park 2556Aug 27, 2017 6:50 pm yourpalcliffy Ausman yourpalcliffy Is it mandatory to render the piers and porch area? I do not see any such requirement in the design guidelines. My builder says its a developer requirement. Could someone please confirm? Thanks in advance. Rendering is not Mandatory but is one of the options, you can also go with Moroka Paint (cheaper than rendering). If you see on Elara blvd there is a mixture of Render and Moroka paint on the front facade of the houses. Thanks Ausman could you please confirm if we need to paint/render the porch walls also or it is the requirement just for the piers? yourpalcliffy, It is not mandatory at all, my house does not have any render / moroka paint to the porch, mine is just on the balcony. For me, I remember the requirement was to have 3 types of materials to be used on the front facade, it can be any combinations. All the best ----------------- Eden Brae Cremorne Blog : http://newhouse.gores.com.au Re: Stockland Elara at Marsden Park 2558Aug 31, 2017 12:29 pm Hi everyone and Kaycee Hope most of the stage 16 commenced construction. I just finalised my tender with Wisdom Homes. They advised it would take 6 weeks to get the contract plans. Please advise how long does council take to approve plans? I have to commence construction by 7th Jan 2018. I am a bit worried whether I have enough time. Please suggest if anything that I can do to accelerate approval process. Re: Stockland Elara at Marsden Park 2559Aug 31, 2017 12:32 pm ElDream16 Hi everyone and Kaycee Hope most of the stage 16 commenced construction. I just finalised my tender with Wisdom Homes. They advised it would take 6 weeks to get the contract plans. Please advise how long does council take to approve plans? I have to commence construction by 7th Jan 2018. I am a bit worried whether I have enough time. Please suggest if anything that I can do to accelerate approval process. It depends if you are taking your plans approved via council or CDC. If it's CDC, plans usually get approved within 10 business days. Just also be aware that most builders are still on holidays in early January and things don't normally return to normal until mid January. Cheers. Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au A Mobile Solicitor at Wong & Horta Lawyers Website: http://www.whlawyers.com.au |
