Browse Forums Renovation + Home Improvement 1 Jul 17, 2017 12:33 am Hi It is my first time posting here so sorry if i am doing anything wrong. In a bathroom renovation with a timber floor and subfloor, my question is that is it ok to put cement sheeting 6 mm directly on floorboard. And then water proof and screed and tile? Is there anything required for the shower area? Is it ok to use gyprock aquacheck for the walls in shower area? I appreciate your assistance in answering my question. Cheers Re: Renovating bathroom 2Jul 17, 2017 9:31 am Hi mate, the 6mm sheet can be used, although I would advise against it as a more durable 16mm compressed sheet would normally replace the timber floor below. With the 6mm if it's not installed properly there is to much risk of movement with the floor boards below that can cause problems with your tiled floors in the future. With the walls aquacheck can be used, although 6mm villaboard on all walls is again a better finish for walls with full height tiles. Good luck with it all. Regards James Mason www.renovationjunkies.com.au Re: Renovating bathroom 3Aug 09, 2017 11:32 pm It would be better if you used 16mm compressed sheet instead of 8 mm compressed sheet . By using it , it became highly durable & stay for long time. What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 4255 Please google this video regarding the Regulations for a Laundry trough: i-dont-want-laundry-tub-can-i-use-sink-instead 13 12182 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 4192 |
