Browse Forums Lighting + Lighting Design 1 Oct 18, 2016 10:07 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: LED lights in shower niches 2Oct 23, 2016 9:29 am Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: LED lights in shower niches 3Oct 28, 2016 7:48 pm Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: LED lights in shower niches 4Aug 06, 2017 12:21 pm bpratt It looks pretty, and trendy, and all the rest, but it is unsafe. Is it really unsafe if it's extra low voltage LEDs and the driver is placed securely away in a waterproof location ? PD . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: LED lights in shower niches 5Aug 06, 2017 12:29 pm Pepsi_Drinker bpratt It looks pretty, and trendy, and all the rest, but it is unsafe. Is it really unsafe if it's extra low voltage LEDs and the driver is placed securely away in a waterproof location ? Now that's post from the crypt ! Well I'm guessing LED's with IP66 ratings would be fine if they are also low voltage, but I'm not sure if it would pass standards though. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: LED lights in shower niches 6Aug 06, 2017 12:37 pm Mine are ip65 and also in diffuser casing. They are recessed up into the niche. Even when I'm cleaning I don't think there's ever been a need to directly spray water on them. M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: LED lights in shower niches 7Aug 06, 2017 4:41 pm Hi Mrs JM..... How did you get the power to the LED strips and where are the drivers ?? Thanks, PD . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: LED lights in shower niches 8Aug 06, 2017 5:18 pm bpratt 1960sModernistHome I blame The Block for perpetuating these trends. a big +1 to that. It looks pretty, and trendy, and all the rest, but it is unsafe. Make that plus 2. I wouldn't want to do it and when you need to replace the LED light when it's dead it might become your worst nightmare. Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au A Mobile Solicitor at Wong & Horta Lawyers Website: http://www.whlawyers.com.au Re: LED lights in shower niches 9Aug 07, 2017 7:38 am I keep hearing "But it's unsafe" but no-one is suggesting that they're going to use a cheap Chinese bed-side lamp in the shower area !! I was thinking, off the top of my head, having a strip of (say) IP67 LEDs at the top of the niche. In the back corner of the niche have a small conduit running UP inside the wall cavity where the 12v power lead could run to the driver nice and safe and dry in the ceiling. So there's only 12v (in a sealed IP67 lighting fixture) in the shower niche and any stray water would have to fall UP around two metres to get anywhere near the driver. PD . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: LED lights in shower niches 10Aug 07, 2017 8:31 am Pepsi_Drinker I keep hearing "But it's unsafe" but no-one is suggesting that they're going to use a cheap Chinese bed-side lamp in the shower area !! I was thinking, off the top of my head, having a strip of (say) IP67 LEDs at the top of the niche. In the back corner of the niche have a small conduit running UP inside the wall cavity where the 12v power lead could run to the driver nice and safe and dry in the ceiling. So there's only 12v (in a sealed IP67 lighting fixture) in the shower niche and any stray water would have to fall UP around two metres to get anywhere near the driver. PD This is more or less my set up. The electrician left the electrical cable out of the wall when the waterproofing was done. The led's and diffuser casing was then installed after the tiles were laid on the back wall of the niche and then they tiled up to the casing. Only issue is the idiot at the shop provided the wrong diffuser case and the top doesn't pop out easily. In fact I think when the strip needs to be changed we will have to smash the casing. Hopefully that's not for a long long time or until after we sell and move and I won't have to deal with it! M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: LED lights in shower niches 11Aug 07, 2017 9:24 am wongbruce bpratt 1960sModernistHome I blame The Block for perpetuating these trends. a big +1 to that. It looks pretty, and trendy, and all the rest, but it is unsafe. Make that plus 2. I wouldn't want to do it and when you need to replace the LED light when it's dead it might become your worst nightmare. I could imagine at that stage, you could possibly damage the water proofing and create a huge job to rectify the same. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: LED lights in shower niches 12Aug 07, 2017 10:49 am bpratt [quote defaultattr=""]× I could imagine at that stage, you could possibly damage the water proofing and create a huge job to rectify the same. /quote] This stage is a vacant block of land !! That is why I was thinking of having the builder drop a conduit through the cavity wall terminating (say 25mm) into where the shower niche will be built. Then the villa-board goes on and the conduit comes through the board and is sealed like any other penetration such as taps / mixers / shower jets. Then the tilers do their thing and once tiled the excess conduit it trimmed flush with the tiles at the top of the niche. Finally, the LED strip can be stuck to the 'roof' of the niche and the 12v feed wire fed UP the conduit (with a dab of silicon) to the driver in the ceiling. Should the LED strip fail at any point in the future it's simply a matter of plucking out the silicon, disconnecting the LV wire in the ceiling and pulling it back down the conduit. A smart person would tie a draw-string to the wire as they pulled it down to simply draw a replacement cable back into the ceiling. Any issues with this ?? PD . Block settled 07 June 2011 Our little piece of the Interwebs on HomeOne....... viewtopic.php?f=31&t=48577&start=0 Re: LED lights in shower niches 13Oct 04, 2022 10:04 pm I would also recommend you to consider installing dimmer for the strip LED lights. So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23367 Which ceiling hook to use to hang Xmas lights under Eaves in 1st floor in 2 storey façade (no… 0 1444 |
