I arranged both of mine
Sent from my iThing via Tapatalk
Browse Forums Building A New House Re: Who else is building with Eden Brae? 14754Jul 30, 2017 6:47 pm Hello All, A quick one. I have asked to provide a 1200mm wide CSD (cavity sliding door) between my study and hall way the quote for which came back at $893. We are thinking this is a rip off. Does any one know if EBH can do a provision for CSD so that i can get it doen post handover? Thanks Re: Who else is building with Eden Brae? 14755Jul 30, 2017 10:24 pm Jahangir Hi guys, my construction is close to finish. Building Livingstone house. I can see some hairline cracks on the slab of my front bedroom and also alfresco slab. Anyone have seen this? Should I be worried? Bedroom: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Alfresco : Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Jahangir Did you ask EBH to fix these cracks, mate? Wondering what you end up doing with these? I'm building a Livingstone as well! Thanks! Who else is building with Eden Brae? 14758Aug 03, 2017 5:29 pm Hello All, I am thinking to get 600 x 600 tiling done externally in all the dry areas. I will be getting all the wet areas done by Edenbrae. Has anyone who have build with EBH shed some light on it? Pros and Cons pls... Like would that be considered as the breach of the contract? and so on Also if you could please share your experience as well in doing so.... Thanks in advance Re: Who else is building with Eden Brae? 14759Aug 04, 2017 1:02 am kunalg Hello All, I am thinking to get 600 x 600 tiling done externally in all the dry areas. I will be getting all the wet areas done by Edenbrae. Has anyone who have build with EBH shed some light on it? Pros and Cons pls... Like would that be considered as the breach of the contract? and so on Also if you could please share your experience as well in doing so.... Thanks in advance I've answered your other post in regards to this. Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au A Mobile Solicitor at Wong & Horta Lawyers Website: http://www.whlawyers.com.au I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 23414 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223637 |
