Browse Forums Kitchen Corner Re: Caesarstone. Fresh concrete, Raw Concrete 4Dec 30, 2016 11:15 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Caesarstone. Fresh concrete, Raw Concrete 7Feb 05, 2017 7:01 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Caesarstone. Fresh concrete, Raw Concrete 11Jul 27, 2017 4:16 pm lovemy3 MrsJM - how's the fresh concrete going? Are you still happy with it? Does it mark with grease (from butter etc), and if watermarks darken it, how long for it do you have to scrub it out?? There is so much conflicting information given - my mind boggles!! I was wanting to go with a more Matt finish as to me glossy benchtops show up all sorts of smudges and fingerprints, so now I'm all confused! I still like it- anything stubborn comes right off with jif. But most things don't need it. Biggest pain is the Sh!tty installers left silicone all over it so I'm still trying to get that off. Sometimes it looks clean from one angle then I come back later in the day in different light and have to clean it again. Still not as bad as Raven. That bench is like having a newborn! I think it's only manageable because it's light. I think the raw and Sleek would be much much much higher maintenance and less forgiving. I have noble grey in my bathrooms and that's super easy to maintain M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Caesarstone. Fresh concrete, Raw Concrete 12Jul 27, 2017 4:55 pm MrsJM lovemy3 MrsJM - how's the fresh concrete going? Are you still happy with it? Does it mark with grease (from butter etc), and if watermarks darken it, how long for it do you have to scrub it out?? There is so much conflicting information given - my mind boggles!! I was wanting to go with a more Matt finish as to me glossy benchtops show up all sorts of smudges and fingerprints, so now I'm all confused! I still like it- anything stubborn comes right off with jif. But most things don't need it. Biggest pain is the Sh!tty installers left silicone all over it so I'm still trying to get that off. Sometimes it looks clean from one angle then I come back later in the day in different light and have to clean it again. Still not as bad as Raven. That bench is like having a newborn! I think it's only manageable because it's light. I think the raw and Sleek would be much much much higher maintenance and less forgiving. I have noble grey in my bathrooms and that's super easy to maintain Yep, my sleek concrete does show every mark and wipe. Once a week we give it a proper clean using Jiff (which is essentially what the OEM cleaner is) and it comes up as good as new. Until the next time we wipe it down with spray and wipe or similar (because be buggered using Jiff everytime). Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10981 I couldn't attached the photo for some reason. Here is the link to the photo https://pin.it/79jwdMp 1 3137 |
