Browse Forums Building A New House Re: Building with Wisdom Homes 6747Jul 20, 2017 6:53 am Washington29 Hi guys, For those further along in the process, did you keep the fridge space as standard? Just worried that if we get a fridge to fit the width, the depth will be too long and the front of the fridge will stick out...?! BUT... In saying that, I just signed off on the drawings today and very hesitant to cause any further delays! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ All the research we did was that 650 was deep enough for most fridges unless we wanted a really big one (800L+) but most fridges are designed to stick out a bit so the doors can open more than 90 degrees. We made ours 700 deep just to add a bit of extra space for ventilation and the water connection but that was back at contract. We wouldn't have bothered if we had already signed off the kitchen plans. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Re: Building with Wisdom Homes 6748Jul 20, 2017 7:19 am singalg Also, just another question - see how with this Facade, the main entrance door is a bit inside (not aligned with garage wall), did you leave it just like that? We were considering if it is worth bringing the door a bit further out to align with garage door... We had the front facade of our Manhattan 52 level (garage with study) but our council refused to pass the plans. You need to check with your council as they are all different. Manhattan 52 Scrape 8/11/17 Slab 16/11/17 Handover 7/12/18 Re: Building with Wisdom Homes 6749Jul 20, 2017 11:41 am Hey we actually lost space in our study and bedroom to make it bigger. They also dropped the eaves on our portico to make it fit as otherwise the eaves would hit the bedroom windows. Yes there was a cost involved, but it wasn't huge. Maybe 2-3k? I honestly can't remember Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The look of the facade depends on what house you build though. Here's the same facade on 2 different wisdom designs. The smaller one is the majestic, the bigger one is the Manhattan (from memory) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Majestic 40 - wisdom homes Re: Building with Wisdom Homes 6750Jul 20, 2017 12:18 pm @mrsllamas2016 Thank You, for all pics, now I feel may be we need to widen the porch a bit. Are you able to post the plan again with the measurement of porch. I looked through yours old pics and there is no plan. Re: Building with Wisdom Homes 6751Jul 20, 2017 12:51 pm aaron2008 @mrsllamas2016 Thank You, for all pics, now I feel may be we need to widen the porch a bit. Are you able to post the plan again with the measurement of porch. I looked through yours old pics and there is no plan. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Looks like ours is 2.9m Get wisdom to look up our plans if you want. Lot 7 kinglake street kellyville. Surname: Llamas (obviously haha) Building Majestic 40 - wisdom homes Re: Building with Wisdom Homes 6752Jul 20, 2017 1:43 pm Quick pic of our laundry tiles below. Upgraded the tiles there to try and match up to the spotted gum laminate that will go down in the living areas. Its not a great pic, taken @ night, and laundry door needs a good clean. (we can't access inside anymore.) Since lockout, really can't get any good pics anymore. Tiles to all wet areas/balconies hopeful to be complete this week. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 6753Jul 20, 2017 2:04 pm Washington29 Hi guys, For those further along in the process, did you keep the fridge space as standard? Just worried that if we get a fridge to fit the width, the depth will be too long and the front of the fridge will stick out...?! BUT... In saying that, I just signed off on the drawings today and very hesitant to cause any further delays! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building WH Manhattan 44 Ensuite Production Estimates: 13 Nov 2017 DA Approval : 25 October 2017 Contract Sign: 28 May 2017 Tender Sign: 24 April 2017 Request for Tender: 22 Jan 2017 Re: Building with Wisdom Homes 6754Jul 20, 2017 3:20 pm Thank You mrsllamas2016. ours is 2200mm so 700mm less. Scratching heads lol Seems like that with everything right now. Our sales consultant is a very quiet one, no replies whatsoever! Re: Building with Wisdom Homes 6755Jul 20, 2017 3:51 pm Jenifermarie Washington29 Hi guys, For those further along in the process, did you keep the fridge space as standard? Just worried that if we get a fridge to fit the width, the depth will be too long and the front of the fridge will stick out...?! BUT... In saying that, I just signed off on the drawings today and very hesitant to cause any further delays! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ All the research we did was that 650 was deep enough for most fridges unless we wanted a really big one (800L+) but most fridges are designed to stick out a bit so the doors can open more than 90 degrees. We made ours 700 deep just to add a bit of extra space for ventilation and the water connection but that was back at contract. We wouldn't have bothered if we had already signed off the kitchen plans. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ We have a 720L fridge going in, and gave the specs to Knebel at Kitchen design. Our fridge space is 630mm deep, and as advised above, the door hinges will stick out a bit so that the doors can open wider. Personal preference really. Re: Building with Wisdom Homes 6756Jul 20, 2017 4:30 pm ozmonkeyoy nice tiles, are they timber look? We went to PGH Bricks & we have decided on Espresso, so thank you all for your inputs. Now to benchtops & cabinets! Re: Building with Wisdom Homes 6757Jul 20, 2017 7:11 pm aaron2008 @ozmonkeyoy nice tiles, are they timber look? We went to PGH Bricks & we have decided on Espresso, so thank you all for your inputs. Now to benchtops & cabinets! Yes, timber look tiles $52m2 ($17m2 over the $35m2 allowance) but with all the additional laying charges of $67m2 so came out @ $84m2 over allowance - adds up quickly!!!! Espresso is what we chose. Hopefully your brickies are good, our bricks need another clean, as still splotches of mortar over a lot of the bricks. They look good from a distance, but can show up irregularities up close. Good luck with the joinery choices..... Re: Building with Wisdom Homes 6758Jul 20, 2017 8:03 pm Jenifermarie Washington29 Hi guys, For those further along in the process, did you keep the fridge space as standard? Just worried that if we get a fridge to fit the width, the depth will be too long and the front of the fridge will stick out...?! BUT... In saying that, I just signed off on the drawings today and very hesitant to cause any further delays! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ All the research we did was that 650 was deep enough for most fridges unless we wanted a really big one (800L+) but most fridges are designed to stick out a bit so the doors can open more than 90 degrees. We made ours 700 deep just to add a bit of extra space for ventilation and the water connection but that was back at contract. We wouldn't have bothered if we had already signed off the kitchen plans. Building Wisdom Aspiration 31 at Willowdale https://ourwillowdalehome.wordpress.com/ Thank you! That makes me feel better. Building the Washington 29 with Wisdom Homes Re: Building with Wisdom Homes 6759Jul 20, 2017 8:09 pm [quote="Chinoandbebe"]Would anyone have handy the Wisdom USB stick that is given to us when we sign Tender? I need a copy of the price list for upgrades to various homes. If anyone has it could you please let me know & I will give you my email address so you can send me the price list. I have misplaced the USB & cannot find it anywhere /quote] Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Maj-35 Tend:14/7/17,Cont:18/8/17,DA:9/1/18,DEP:1/2,Const:8/3, Slab: 28/3,Frames:17/4-23/4,Bricks:22/5-14/6,URoof: 29/6,elec:4/8,AC,GRoof:11/8,gyp:24/08,Keys:4/12,move:16/12 Re: Building with Wisdom Homes 6760Jul 20, 2017 8:11 pm MandM+4 Our pool went in today and is now settling in before the concrete bond beam goes on early next week. Our signed mortgage docs are on their way back to bankwest in WA, they have said they will get their authority to commence construction letter out within 48 hours of them receiving them. W have to add our variation for dropped edge beams on to our end panel and some of the tiling needs fixing up on our construction plans, so hopefully final documents will be complete this week and we can hand the site over to W as soon as Narellan pools are finished. Starting to feel like it's really happening Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Building Monte Carlo 40- Wisdom homes Exciting! What a beautiful spot. Building the Washington 29 with Wisdom Homes Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18473 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73505 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8241 |
