Browse Forums Building A New House Re: Who's building with Clarendon?? 17504Jul 16, 2017 12:02 am Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Who's building with Clarendon?? 17505Jul 16, 2017 8:43 am wentworth33 Gambit79 To anyone building the Wentworth 33 or thinking about it. The stair design on the plan doesn't work as they have stuffed up the plans so that the powder room wall doesn't line up. They'll try and get you to change the stairs. I pushed them to keep the stairs and simple extend the wall to the top and create a ledge in front of the ballastrade of about 220mm Just an FYI. They know their design doesn't work but won't tell anyone or fix it. Hi Wentworth 33, Can I ask you before making decision to upgrade both ceilings high in tender appointment. As Gambit said stair didn't line up if upgrading extra ceilings high. If I leave it 2450 high, does it look low? We had the promotion upgrade 2600 high ceilings. Thank you Hi Gambit, I am building wentworth 33. The stairs didnt line up because of your extra ceiling height. They wont fix that. According to them, its not their fault as they have followed building code. If you pay attention on the picture, there is gap without baluster which is causing safety risk, but again, they wont do anything as they have followed building code. Technically speaking, your option is to go back to the original height ceiling (2.45m) or pay extra to put balluster at the top or leave it as it. Re: Who's building with Clarendon?? 17507Jul 16, 2017 2:06 pm Your overhead cupboards match that flooring perfectly ... I like the textured look too! My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: Who's building with Clarendon?? 17509Jul 16, 2017 4:49 pm jess98 wentworth33 Gambit79 To anyone building the Wentworth 33 or thinking about it. The stair design on the plan doesn't work as they have stuffed up the plans so that the powder room wall doesn't line up. They'll try and get you to change the stairs. I pushed them to keep the stairs and simple extend the wall to the top and create a ledge in front of the ballastrade of about 220mm Just an FYI. They know their design doesn't work but won't tell anyone or fix it. Hi Wentworth 33, Can I ask you before making decision to upgrade both ceilings high in tender appointment. As Gambit said stair didn't line up if upgrading extra ceilings high. If I leave it 2450 high, does it look low? We had the promotion upgrade 2600 high ceilings. Thank you Hi Gambit, I am building wentworth 33. The stairs didnt line up because of your extra ceiling height. They wont fix that. According to them, its not their fault as they have followed building code. If you pay attention on the picture, there is gap without baluster which is causing safety risk, but again, they wont do anything as they have followed building code. Technically speaking, your option is to go back to the original height ceiling (2.45m) or pay extra to put balluster at the top or leave it as it. Hi Jess, I always go to higher ceiling. 2600 is the minimum, if you can do 2750 is better. Dont reduce the ceiling only because of a small matter. In regards of the stairs, ask Gambit (check his message). he managed to get the stair designer to find the solution for him without any additional cost. Try not to sign stair paperwork till you are happy with it. Building Wentworth 33 CDC lodged to Council : 22 June 2018 Site excavation 31 July 2018 Slab 08 Aug 2018 Frame 22 Aug 2018 Roof 10 Sep 2018 Brick 24 Sep 2018 Re: Who's building with Clarendon?? 17510Jul 16, 2017 5:00 pm Hello has anyone had to do plumbing in the backyard need some advice what to do. .. Like our block is cut to build the house which makes it uneven and the neighbour is saying that we have to put drainage around the house connect to drainage pipes any advices. .. Re: Who's building with Clarendon?? 17511Jul 17, 2017 4:39 pm Hey KLB, I'm thinking of the same colour scheme as well! Just wondering as I read from your blog that you did flooring after - did it cost you just $700 for the kitchen guys to come back to fix up the kickboards? What about the skirting? Did you have to pay someone else to fix those up? My build blog here Re: Who's building with Clarendon?? 17513Jul 17, 2017 8:52 pm Thanks Mrs RS The house is very much still a work in progress. Finally starting to get some art on the walls which makes a difference. Re: Who's building with Clarendon?? 17514Jul 17, 2017 8:54 pm Buildingourfirstnest Hey KLB, I'm thinking of the same colour scheme as well! Just wondering as I read from your blog that you did flooring after - did it cost you just $700 for the kitchen guys to come back to fix up the kickboards? What about the skirting? Did you have to pay someone else to fix those up? Yep we had to pay the $700, killed me to do it but I refused to have scotia! Skirting we were supposed to do ourselves but after major dramas and us ending up getting floors done before handover due to their delays I made them do the skirting, we just had to paint it. Re: Who's building with Clarendon?? 17515Jul 18, 2017 8:45 am KLB Buildingourfirstnest Hey KLB, I'm thinking of the same colour scheme as well! Just wondering as I read from your blog that you did flooring after - did it cost you just $700 for the kitchen guys to come back to fix up the kickboards? What about the skirting? Did you have to pay someone else to fix those up? Yep we had to pay the $700, killed me to do it but I refused to have scotia! Skirting we were supposed to do ourselves but after major dramas and us ending up getting floors done before handover due to their delays I made them do the skirting, we just had to paint it. Ah thanks. Prices must have increased since you built, because I've been given an estimate of $1000 plus for the kitchen guys to come back, and the cabinetry in my kitchen is the same as yours :/ My build blog here Re: Who's building with Clarendon?? 17516Jul 20, 2017 2:12 pm Meliss Hi, I have a question about flooring. I am going in for colours in a few weeks and my boyfriend and I are butting heads about if we should tile or do laminate through the non carpeted areas. I won't say who wants which but can I get some honest feedback on your opinions of these two choices? Particularly we are wondering what maintenance for laminate is like, as we both come from tiles homes. Also is laminate durable at all? E.g. Will it scratch easily if something is dropped on dragged on it like cutlery, plates etc Thanks in advance Hi Meliss, So good that you asked the question. We are also still tossing up between standard tiles or standard laminates. We would like the look of the laminates and also they are good come winter. Only worry we are having is about the durability. Two young kids who often spill stuff on the floor. Would love all the insights and would be great to hear more of your thoughts and findings. Also roughly how much difference would it make if we want to upgrade to timber flooring? Or even better tiles? Thanks Re: Who's building with Clarendon?? 17517Jul 20, 2017 2:39 pm Hi all As mentioned earlier I got my handover next Friday. I did my final housepct inspect on Tuesday. Mind you this was a mission it self. Ss didn't allow them to go in initially and asked them to wait until handover. But long story short I managed to get them in. Warning: don't trust the Clarendons so claimed 200 point check before last two weeks of handover. During my walk through I only saw paint touch up issues. But the report came back with many more small defects which I wouldn't have known. Ex. Insulation on ceiling and sarking is not done properly. Down lights holes not correct size. Cabinet minor damages etc. Interestingly my SS asked for the report so he can give it to the handyman. So I highly recommend getting this final report done on or before your handover. Visit my blog Clarendon Bronte 25 Re: Who's building with Clarendon?? 17518Jul 20, 2017 3:27 pm ajedi2k Hi all As mentioned earlier I got my handover next Friday. I did my final housepct inspect on Tuesday. Mind you this was a mission it self. Ss didn't allow them to go in initially and asked them to wait until handover. But long story short I managed to get them in. Warning: don't trust the Clarendons so claimed 200 point check before last two weeks of handover. During my walk through I only saw paint touch up issues. But the report came back with many more small defects which I wouldn't have known. Ex. Insulation on ceiling and sarking is not done properly. Down lights holes not correct size. Cabinet minor damages etc. Interestingly my SS asked for the report so he can give it to the handyman. So I highly recommend getting this final report done on or before your handover. Great news ajedi2k that you finally your house is completed. .. In regards to sarking and insulation as our gyprock has been done what is not done right. ... I am so feed up with clarendon already can't stand their excuses. .. Its good you are sharing your experience so that everyone is alert what to expect. All the best with your handover. . Re: Who's building with Clarendon?? 17519Jul 20, 2017 3:35 pm Mrs RS ajedi2k Hi all As mentioned earlier I got my handover next Friday. I did my final housepct inspect on Tuesday. Mind you this was a mission it self. Ss didn't allow them to go in initially and asked them to wait until handover. But long story short I managed to get them in. Warning: don't trust the Clarendons so claimed 200 point check before last two weeks of handover. During my walk through I only saw paint touch up issues. But the report came back with many more small defects which I wouldn't have known. Ex. Insulation on ceiling and sarking is not done properly. Down lights holes not correct size. Cabinet minor damages etc. Interestingly my SS asked for the report so he can give it to the handyman. So I highly recommend getting this final report done on or before your handover. Great news ajedi2k that you finally your house is completed. .. In regards to sarking and insulation as our gyprock has been done what is not done right. ... I am so feed up with clarendon already can't stand their excuses. .. Its good you are sharing your experience so that everyone is alert what to expect. All the best with your handover. . RS. yes your sarking shouldn't have any issues at this stage however your insulation on the ceiling doesn't need to be perfect. They actually don't complete roof insulation until both aircon and electrical final fit out. Ie ceiling insulation is the last job on your roof. I knew my one will have issues, eureka insulation guy was there past 7pm working in the dark, I can only assume he had a head light on. But obviously he missed the quality check after the final job. Visit my blog Clarendon Bronte 25 Re: Who's building with Clarendon?? 17520Jul 20, 2017 4:14 pm ajedi2k Hi all As mentioned earlier I got my handover next Friday. I did my final housepct inspect on Tuesday. Mind you this was a mission it self. Ss didn't allow them to go in initially and asked them to wait until handover. But long story short I managed to get them in. Warning: don't trust the Clarendons so claimed 200 point check before last two weeks of handover. During my walk through I only saw paint touch up issues. But the report came back with many more small defects which I wouldn't have known. Ex. Insulation on ceiling and sarking is not done properly. Down lights holes not correct size. Cabinet minor damages etc. Interestingly my SS asked for the report so he can give it to the handyman. So I highly recommend getting this final report done on or before your handover. Hi there, Thanks for the advise. Can I ask who did your inspection? Thanks the stair balustrades? There is nothing special about these and I imagine literally every stair installer will be able to do this. 1 6748 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7873 |
