Browse Forums Home Theatre & Automation 1 Jul 05, 2017 8:17 pm Hi all, We are building a double story home thinking to have home theatre cabling and security cabling under construction Can some one give me any ideas what things need to be done for home theatre and other cabling in house Any other ideas which things are important to be done while house is under construction Thanks Re: Home theatre cabling and security cabling 2Jul 05, 2017 11:08 pm Wire for the best acoustics you can afford e.g 7.2 so down the track no problem for upgrade. Projector and screen wiring. Considerations for main equipment area -- if you have linen cupboard close by, it would look much neater and cleaner to put stuff in there. Think about what equipment you will have and put in as many PP as you need -- avoid use of ugly power board. Re: Home theatre cabling and security cabling 3Jul 10, 2017 12:44 pm I have just gone and requested the above prewiring from my builder so Ideas are fresh Home Theatre Although 7.1 or .2 is great. if the room is between 5 to 7m of length I would stick to 5.1. Rooms above 8 metres by all means 7.1 but you will be wasting money on the 7 speaker wiring. If you can prewire yourself get a couple of rolls of cable and wall plates and do it yourself. With my build my builder has to do it as they do wiring inhouse. Alarm System Consider an alarm system to be done also either prewire or the full install. Surveillance System In my case I am getting an 8ch pre wire cat6 cabling done and will do the cameras/NVR/DVR myself. Re: Home theatre cabling and security cabling 5Jul 13, 2017 8:20 pm the 5.1 wiring is $1140 times two as I am doing two rooms in 5.1. Alarms system with 8 pir's just over 2k. (IP capable and touchscreen) Re: Home theatre cabling and security cabling 7Jul 14, 2017 6:30 pm it is not monitored if that is what you are asking. It will email you when something goes wrong however. It's all about wireless, self install now. The cost/benefit of wired setups for the house are no longer what they used to be. Lots of wireless options. Eufy, Arlo and… 2 9987 It seems very clear to me that your contract states that a security account does NOT need to be established so the answer to the builder is NO. If in doubt find a contract… 1 8694 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38578 |
