Browse Forums General Discussion Re: Has anyone rectified slab heave successfully 881Jul 03, 2017 11:01 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Has anyone rectified slab heave successfully 882Jul 04, 2017 6:12 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Has anyone rectified slab heave successfully 885Jul 04, 2017 1:14 pm Looking at new home approvals, March 2015 seemed to be the peak, so the more work, the more chances, poor work will effect more builds. Education, research, hire the right people including knowledgeable inspector not including builder provided inspectors, in short boy do we need more good inspectors like building expert. Re: Has anyone rectified slab heave successfully 886Jul 04, 2017 3:08 pm Liliana insider Starting to see a new wave of slab heave houses constructed between 5/2015-6/2016 it's all happening again.Looks like we have learnt nothing from the pre 2011 slab heave houses. Is there something about that particular period that is making the houses more vulnerable? Re: Has anyone rectified slab heave successfully 888Jul 04, 2017 3:45 pm State wide, June was Victoria's driest June on record and we are also heading into El Nino. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Has anyone rectified slab heave successfully 889Jul 04, 2017 4:20 pm Certainly could happen again we are in a long term rainfall deficit so a couple of dry years and the clay will be very dry again. Moisture contents were lower than 12% in some places during the second halve of 2015, now the would be closer to 30% Re: Has anyone rectified slab heave successfully 890Jul 05, 2017 1:35 pm Nothing will ruin your slab like a leaking sewer drain under the slab. Today I inspected for pre slab and found sewer waste loose and damaged by concreters. You would not pick it up unless you knew where to look. Luckily builder's plumber was around the corner and fixed it before I left. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Has anyone rectified slab heave successfully 892Jul 11, 2017 9:09 pm Mee too , but also ome going through sewer lines as well, How do you fix it Check out my blog http://www.buildingexpert.net.au/blog/b ... egistered/ Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Has anyone rectified slab heave successfully 893Jul 12, 2017 7:36 pm Just shocking, how the biggest purchase most will ever make is so easily butchered to so many. It would be good to have a BEFORE you build thread that could have advice that to most is simply not obvious, maybe in simple point form, most unfortunately just check displays, and then think, I'm done. Their not thinking, inspector, Learn, speak to previous customers, educate yourselves etc. Re: Has anyone rectified slab heave successfully 895Jul 30, 2017 11:07 pm Just an update from my post in 2014, where I found and reported a severely dished slab on a house in Wyndham Vale. It seems my client sold the property. New purchaser has just now found out he has a problem. When I asked whether they got pre purchase inspection the answer was yes, by a franchised inspector who did not pick up on severely dished slab. This is the second time I came across franchised inspectors missing an elephant in the room. On a pre purchase inspection in Eltham they missed 50mm floor subsidence at rear of the house. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Has anyone rectified slab heave successfully 896Jul 31, 2017 6:40 am building-expert Just an update from my post in 2014, where I found and reported a severely dished slab on a house in Wyndham Vale. It seems my client sold the property. New purchaser has just now found out he has a problem. When I asked whether they got pre purchase inspection the answer was yes, by a franchised inspector who did not pick up on severely dished slab. This is the second time I came across franchised inspectors missing an elephant in the room. On a pre purchase inspection in Eltham they missed 50mm floor subsidence at rear of the house. If the seller was aware of that serious defect and sold the property without disclosing it they can be in a lot of legal hot water. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: Has anyone rectified slab heave successfully 897Jul 31, 2017 10:12 am been reading a little bit on slab heave recently ever since i went on site and had a walk though neighboring houses already under construction in my estate funding a week of heavy rains. I noticed more than a few had no temp downpipes and pools of water a meter or 2 from the slabs while another builder had temp downpipes leading into the stormwater drains
I was encouraged by my building consultant to do my stormwater etc myself after handover to save money but now wondering if it was a mistake or if they still woudn't have used temporary downpipes. during a 5-6 month construction window thats potentially a lot of water draining into soil near the slab which i assume may increase risk of slab issues (soil in area is h2-d) i guess the solution is to ask my site supervisor about putting in the stormwater as early as allowed on a weekend and putting my own temp downpipes in with other recent developments that i did not anticipate im begining to wish i had done taken a lot more time for research before signing. Re: Has anyone rectified slab heave successfully 898Jul 31, 2017 1:18 pm I've tended to use owner type inspectors who were all very experienced, similar in setup to building expert and found them knowledgeable and a eye for detail, trouble is some have barely enough qualifications and or experience and maybe not enough care factor. Re: Has anyone rectified slab heave successfully 900Jul 31, 2017 1:52 pm Joker my thought is if stormwater is being done after handover then there is nothign for temporary downpipes to be connected to anyway hence i am going to be asking if i can get access to the site to do my stormwater earlier in the build process
my exes new partner used to work as a building inspector and now works for the local council in the area im building in and he has offered to check on my build for me through out construction. but planning on getting a couple of more detailed inspections as well i think at certain points - just got to find one in the area that i like. Hi All, we are starting to think of building with Masterpiece Builders in Victoria, has anyone had any feedback or experience with them 0 13883 Hi we are looking to talk to people who have built with them recently. We have signed mid range built contract but identified that a lot of things are not included.… 0 764 I work with owner, he/she is my man on the ground and I instruct them when to visit the site and take photos and I have other tools in the bag. 4 15503 |
