Browse Forums General Discussion Re: Cost of installing downlights after handover 2Jul 01, 2017 9:24 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Cost of installing downlights after handover 4Jul 03, 2017 2:20 pm Thank you everyone for your replies. If I get downlight installed after build, do I need to get builder to put wiring in the ceiling for each downlight that will be installed or it can be performed with extra time after build? Re: Cost of installing downlights after handover 5Jul 04, 2017 9:06 am mishmu Thank you everyone for your replies. If I get downlight installed after build, do I need to get builder to put wiring in the ceiling for each downlight that will be installed or it can be performed with extra time after build? I'm saying this sight unseen but you shouldn't need to worry about the builder putting any extra wiring in. If you have an electrician putting the downlights in post build you may as well get them to do the extra wiring themselves. Re: Cost of installing downlights after handover 6Jul 05, 2017 4:13 pm You are better off removing the battens and replacing them with downlights or provisions by the builder as you will get a credit for the battens. We are doing a double storey so went with downlights provisions. It was around $60 cheaper to get the provisions put in place when we can buy the downlights for around $25 each. The downlights just plug in to the provisions so no electrician required. Building Monte Carlo 40- Wisdom homes Building Monte Carlo 40- Wisdom homes 2 2536 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 37225 multiple occ properties are always billed by trades at a premium, rarely per sqm for the lot. You either have trades you know whoe will do by sqm or youre going to get… 1 2275 |
