Browse Forums Building A New House Re: Arden Homes - Votivo 43 - New home build 4Jul 03, 2017 8:09 am follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Arden Homes - Votivo 43 - New home build 5Jul 03, 2017 8:14 am Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Arden Homes - Votivo 43 - New home build 7Jul 03, 2017 8:16 am Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Arden Homes - Votivo 43 - New home build 9Jul 03, 2017 8:23 am Follow our Arden Toulouse build at http://ardentoulouse.blogspot.com.au Re: Arden Homes - Votivo 43 - New home build 18Jul 03, 2017 9:34 am g33kerb0t I did forget to mention, we asked Arden to put floor wastes to all wet areas: - ensuite and toilet area - gf shower - 1st floor bath - 1st floor powder (toilet area) - laundry We couldn't understand why this is not "standard" with builders, particularly in VIC. We have a friend in Perth who had this in their house as standard. Read in other forums that they do this in other states too. What happens if you are away and you got a pipe burst in these areas? Where would the water go? Thankfully Arden does this kind of modification. Others don't. This is one of the reasons that drove us away from H and the other major builders. By the way, these didn't cost too much to add. Only a few hundred in total. I did the same - was worried cos last time my kid pulled out the washing machine hose and had water all over. I asked for alfresco too during colour and at tender they quoted for 3 saying alfresco waste point is included but in contract found it missing. They said it is not standard for alfresco. Total cost for 4 waste points around $784 or 196 each. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Arden Homes - Votivo 43 - New home build 19Jul 03, 2017 11:29 am g33kerb0t Here are our floor plan sketches. Ground floor changes: - Convert Rumpus to Alfresco - Increase garage width by 1.5m and add roller door at the back - Shower to powder room customisation - Move fridge space to left side of the kitchen (same side as the powder) - Swap pantry and laundry - Move laundry door to new laundry - Remove included SMEG freestanding cooktop and replace with SMEG PGA96 cooktop and SMEG SA940CXA rangehood - Add single wall oven tower (with space for stacked ovens) where the original fridge space was - Modify kitchen drawers/cabinetry as per drawing - Increase kitchen benchtop depth to 1.1m (was originally 900mm) - Add window splashback to pantry and laundry - Add single square sink in pantry - Add base and overhead cabinetry in pantry - Add built-in pantry to pantry (will be converted to pull-out later on) - Add hafele euro cargo pull-out bin in kitchen - Add stone benchtop in laundry - covering washing machine and dryer - Add overhead cabinetry to laundry - Add french type doors in study (could still change) - Add sliding doors to home theater - Bigger entertainer stacker doors to alfresco (may change to entertainer bi-parting if budget allows) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ First Floor changes: - Changed ensuite layout as per drawing - Increased shower screen size in Bath - Dual vanity in Bath - Drawer tower inside WIR in all rooms Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Love your floor plan. All the best with your build! Re: Arden Homes - Votivo 43 - New home build 20Jul 03, 2017 8:32 pm g33kerb0t Not yet. Will find out at tender. I believe it should be just a few hundred, even less, as you're not really adding new cabinets. At least that's what they said during colours. Do you know how much it is to change laundry laminate top to stone? Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 48396 If you are in Victoria you have a statutory right to your own building inspector regardless of builder's consent. No negotiations are required. However the builder will… 1 3481 That's brilliant would appreciate if you have you can locate the other doc so I can use it with my discussion with the building surveyor 10 2327 |
