Browse Forums Safer Living Re: Wireless vs Wired home alarms? 3Jun 27, 2017 10:41 pm I'd say if you could have a complete wired alarm system installed at building stage, it'd be the better option. You wouldn't have to worry about replacing batteries in PIRs and reed switches and have detectors lose communications. Although I'm not against wireless alarm components, I wouldn't lean towards a complete wireless alarm but that's my opinion. hth Re: Wireless vs Wired home alarms? 4Jun 30, 2017 10:54 am Pre-wire is good option. Data Cabling and Security Service - www.leact.com.au 0488 033 022 Data Cabling NBN MDF Jumper IT Network Alarm CCTV Access Control Intercom Re: Wireless vs Wired home alarms? 5Sep 26, 2017 10:55 am g33kerb0t Hi All, I am about to do a new house build and i am going through the electricals with my builder. I'm building a double storey house and I'm just wondering, is it worth doing the home alarm pre-wire or are wireless home alarm solutions good enough? What are your experiences on wired vs wireless? Anyone heard about wireless home alarms being jammed by intruders? Thanks in advance. I will always prefer wireless security system as wired security system can mess sometimes if not installed properly. If you prefer to choose hardwired security system, you need to be very careful about the installation and placement. Don't know if electrician can pay so much attention while installing. A wrong placement of detector for example if it is in front of your window, it will set the alarm off every time vehicle passes by. Get a licenced technician to install it. Re: Wireless vs Wired home alarms? 6Sep 27, 2017 8:48 am Hardwired is always better No batteries to change, no range issues Use a security installer not an electrician, security installers need to be licensed in most states, so check as each state has its own requirements. Re: Wireless vs Wired home alarms? 7Apr 15, 2020 5:01 pm A wireless home alarm system is best. No need for drilling holes or making other modifications. But make sure to choose high-quality security gear. Re: Wireless vs Wired home alarms? 8Apr 16, 2020 8:02 pm I think wired is best too because then you don't have to worry about changing batteries etc. I do agree that get a professional security company to have a look at the placement of the detectors. I initially suggested a few locations which I think is suitable but the professional changed it and explained to me. All are great reason. Re: Wireless vs Wired home alarms? 9Jun 09, 2020 3:49 pm wired too:-D Data Cabling and Security Service - www.leact.com.au 0488 033 022 Data Cabling NBN MDF Jumper IT Network Alarm CCTV Access Control Intercom Re: Wireless vs Wired home alarms? 10Apr 28, 2021 8:45 am I can only speak on Bosch alarms, but in general wireless and wired are good the only problem with wireless are they require batteries of cause and they go into a 3 minute sleep cycle after being triggered once even if the alarm is not armed. If you can get it pre-wired it will be better for future reasons encase you upgrades that don't support wireless. TRANTECH SECURITY WHOLESALER 26 Davies Ave, Sunshine North VIC 3020 T: (02) 8722 0348 (Syd) T: (03) 9079 5566 (Mel) www.trantechsecurity.com.au Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5910 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16720 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110944 |
