Browse Forums Paving & Concreting 1 Jun 24, 2017 3:04 pm Hi All, I am wondering if slab poured edge can be like these photos. If this is normal, that is fine. Otherwise, I wouldn't pay for this. Please advise and let me know what if I should do anything about it. Thank you in advance. http://imageshack.com/a/img923/7764/Y4f98b.jpg http://imageshack.com/a/img923/2697/RqWfTG.jpg http://imageshack.com/a/img923/5097/AMQgWg.jpg http://imageshack.com/a/img922/8373/IzNqh3.jpg Re: Slab poured - Good or Bad 2Jun 24, 2017 7:38 pm The slab corners/edges look scrappy and Id be wondering why they ended up looking like that? Looks like heavy equipment has been backing over onto your slab. Thats a no no. The earth around the slab should be graded and sloping away from the slab to divert rain water away.. The whole thing looks like a mess. You have cowboys working there who dont give a sh1t. Id employ an indepedent building inspector for this project because you might be in for lots more woes by the looks of it. Hello needing some advice. I was about to build my Alfresco and needed a new slab and remove exisiting slab as its not standard. So they start to excavate and jackhammer… 0 10702 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16150 do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28290 |
