Browse Forums Building A New House Re: Building in Melbourne with Metricon - Delta 25 8Jun 21, 2017 6:18 pm Cellaraso Is it possible to extend the master as we felt it was slightly on the small side? I never asked but it should be possible depending on your desired facade. We have a queen size bed and side tables and have about 400mm total space between the side table and walls so increasing the length by 1000mm will let you fit a king without trouble. Our ceiling is 2700 in all areas (garage is 2850 due to the lower slab) and a 300mm drop ceiling in the kitchen. Re: Building in Melbourne with Metricon - Delta 25 10Jun 23, 2017 2:15 pm Cellaraso @pauldab Did you block off the front of the house from the back with doors? Or block off the lounge? no, all open. I kept the floorplan basically the same check my build thread (in my sig) for plans and pics Re: Building in Melbourne with Metricon - Delta 25 12Jun 26, 2017 4:22 pm I have just signed and sent the initial paperwork through with a quote estimate which I share below. May give you some ideas of what to consider for upgrades. These prices are not final, only indicative quote. Please note, I am doing flooring and driveway post-handover. HOUSE: DELTA 25 FREEDOM RANGE SUMMARY HOME $188,200 PROVISIONAL SITE WORKS $34,405 UPGRADES $32,444 TOTAL $255,049 DETAILS PROMOTION
SITE WORKS
OH&S REQUIREMENTS
COUNCIL REQUIREMENTS
DEVELOPER REQUIREMENTS
* Water tapping. * Associated fees. * Water meter assembly. * Recycled water garden tap to rear perimeter of house. * Recycled water garden tap at meter assembly with approved sign. * Recycled water run-in up to 6 lineal metres. * Connection to (2No) toilet suites. STRUCTURAL
EXTERNAL
CAR ACCOMMODATION
* (2No) Premium Tri-Tran remote control transmitters. * (1No) Wall mounted transmitter. * Automatic Festoon courtesy light. * (1No) Single power point
WINDOWS
FRONT ENTRY
ENSUITE 1
* Additional 90mm stud wall where required. KITCHEN
$70 Wall Cabinets - Seen Provide 16mm thick (nom) Laminate Seen End Panel (up to 800mm high x 450mm deep) to wall cabinets.
* Increase width of standard benchtop (up to 1100mm) including up to (2No) laminate end panels. * Void inside Island bench to support benchtop (as required). * Up to 250mm overhang to rear of Kitchen Island bench.* Laminate finish.
PANTRY
BEDROOM 2
BEDROOM 3
BEDROOM 4
BATHROOM
* Additional 90mm stud wall where required. WATER CLOSET
DOORS - INTERNAL
ELECTRICALS
* (1No) Paradox 10 Zone Security Panel. * (1No) LED keypad. * (3No) Movement Detectors. * (1No) Internal siren. * (1No) External siren. * (1No) 12v Back up battery. * (1No) 240v power supply. * (1No) Single power point.
* (1No) Pay TV outlet (RG6). * (1No) TV Outlets (RG6). * (1No) Telephone Outlet. * (1No) Data Outlet. * (1No) 25mm conduit with drawstring from fibre wall outlet (FWO) to meter box. * Includes trenching and installation of conduit (with drawstring) from access pit to metre box (up to 25 metres). * (1No) Double power point. COOLING
* Seven outlets. * Manual wall thermostat control. * Auto dump valve. * Weatherseal. * Water point. * Single power point. * Upgrade of roof trusses. Re: Building in Melbourne with Metricon - Delta 25 14Jun 30, 2017 9:01 am We're thinking of laminate flooring and we got a quote from floor world in caroline springs from $60 to $80 per square meter. This price factors in underlay and installation. Of course there's more expensive types but this is within our budget. From what i understand, if you go with the basic flooring package with Metricon, it works out cheaper but if you upgrade, it works out cheaper through a third party. Re: Building in Melbourne with Metricon - Delta 25 15Jul 06, 2017 11:22 pm Today we looked at flooring, which, as I mentioned, we are doing post handover. Checked out Western Distributors in Sunshine to look at timber look laminate and carpeting. Highly recommend for customer service and reasonable pricing. Here are some photos: Different laminate flooring options. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Some carpet options Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We ended up choosing the Bordeaux Monterey laminate. 12mm thick AC3 rating. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And for carpet, chose the Quest Metropol Granite, a solution dyed nylon twist pile. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Just got a quote and some sampels. I will pay a deposit after we do our colour selection with Metricon. Re: Building in Melbourne with Metricon - Delta 25 17Jul 18, 2017 3:41 pm Don't expect that to be much of a tool to track actual progress. I only used it to make sure payments from the bank hit their account so we didn't get hit with problems. Re: Building in Melbourne with Metricon - Delta 25 18Jul 19, 2017 2:27 pm Cellaraso @pauldab Did you block off the front of the house from the back with doors? Or block off the lounge? Nice one Cellaraso. We're building the Helsinki (now moved down a category and rebranded the Berkshire) which is very similar to the Delta 25, just a fair bit bigger. We did put cavity sliders to the minor bedroom wing, to block off the noise from the living. I also put double cavity sliders to the formal lounge, so that we can throw the guest children in there with movies and shut the doors Re: Building in Melbourne with Metricon - Delta 25 19Jul 19, 2017 4:08 pm pvbuild what stage are you at in the process? Your plan is very similar, we have a small block so 25 squares is pretty much the maximum we can fit. I thought of blocking off some areas but decided against it to keep the open plan vibe. May be kicking myself when the kids are wreaking havoc! Are you building in VIC? Re: Building in Melbourne with Metricon - Delta 25 20Jul 19, 2017 4:12 pm Yep, in Vic. Metricon are starting to brick tomorrow - we've had about 6 weeks of delays due to a slight muck up with the garage boundary design, but that should be solved now. Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8200 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10749 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17332 |
