Browse Forums Building A New House Re: Building Journey : Henley Reserve Aegean 38 2Jun 20, 2017 12:12 pm _________________________________________ Regards Manj https://forum.homeone.com.au/viewtopic.php?f=31&t=88256 Re: Building Journey : Henley Reserve Aegean 38 15Jun 20, 2017 4:37 pm great. Our land size is big so can't have small or single story house. Our Site Cost came back $18k with all estate requirement. Re: Building Journey : Henley Reserve Aegean 38 16Jun 23, 2017 7:55 am laoskiwi Around the $15K mark ... The set up is that the gas ducted heating is zoned to either heat the whole house, or downstairs only, or upstairs only. And the refridgerative cooling is designed to either cool downstairs or upstairs. It does not have capacity to cool both. We are happy with that though as it's only the 2 of us in the house and it will more than meet our needs. Did that $15k price include converting your power to 3 phase? I'm with another builder, doing the same cooling upgrade (they also use brivis like henley) and they advised that for the capacity required, it will need 3 phase ac. Building the Arden Votivo 43 Follow me here: https://forum.homeone.com.au/viewtopic.php?f=31&t=88553 Re: Building Journey : Henley Reserve Aegean 38 18Jun 24, 2017 4:11 pm I am considering to build Aegen 38 too I have not got back the site cost yet. This would be the only thing i worry about as my lot is at hill top with slight slop. laoskiwi do you mind if I am asking some upgrade price from Henley that they quote you ? 1. Ultimate Facade - What is the extra cost for rendering? 2. Do you raise your ceiling height ? I am thinking to do that to 2.7m 3. Floor tiling & carpet - do you go with Henely or do it with 3rd party after handover? 4. Did they offer you for electrical upgrade option ? Thanks laoskiwi Re: Building Journey : Henley Reserve Aegean 38 19Jul 09, 2017 9:11 pm laoskiwi Site Costs Back: $29K ... We were expecting more due to the amount of fall on our land >1.2m ... however building double storied has reduced our building envelope and consequently the amount of fall over the building area... We were quoted $25K from another builder for single storey so pretty happy with this even tho on the upper end of the scale. If we consider the m2 of our home ... this Aegean build is better value for money than building some single storey homes. Great choice in the Aegean (we are a little biased ). We've got 1.3m of fall over the whole block so it's good to have an estimate. We've only just had our soil and site tests done so still waiting on costs. We'll find out in August when we have our tender. Re: Building Journey : Henley Reserve Aegean 38 20Aug 09, 2017 3:12 pm bhutani.sumit We didn't opt for Cooling instead ask for future plumbing for $500. Got the zoned Heating as you said for $2215. i am sure price would be the same for you as well. Hi Bhutani,I'm planning to build Cullen 45 from Henley (double storey) .I'm not clear what you said about future plumbing and zoned heating $2215. My assumption is the default heating provided by Henley can heat up both ground floor and first floor and I will be ale to control the heating between floors. As I have a tight budget at this point .I cant afford cooling now. So planning to put 500$ to provide plumbing work for cooling and later down the line I can add colling sytem. Is this correct ? also why did you paied $2215 for zone heating? Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7214 Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 10506 |
