Browse Forums Building A New House Re: Building with Wisdom Homes 6413Jun 17, 2017 9:28 pm ajayshekar MandM+4 So frustrated today. Variations through- one privacy screen about 1.5mx1.5m W want over $2k for. It's daylight robbery. It first came through as screenS for the elevations of master balcony, when in fact it's just one screen for the front balcony, so I was hoping the price was way off. They redid the wording but price still the same. Then I get told we can't delete our heat pump HWS incase the solar doesn't work on a cloudy day (it has electric boost), both systems are around $4000. I'm sure we'll get it resolved but the emails back and forth and waiting for things to be sorted out is just wasting time and causing me stress! We are waiting on our draft end panel to finalise our finance so we can get the pool in and get going. Aaaargh Building Monte Carlo 40- Wisdom homes Hello MandM+4, i spoke to the council and was advised i can submit a sigmed statutory declaration saying that i will install privacy screens to balcony after interim OC but before Full OC. W also agreed to this after cross checking with council. W can still apply for IOC and can still handover as per normal. Bank will also be happy. We get 30 days to install privacy screen from IOC. BTW i was being charged $7200 for privacy screens by W. Same by better view blinds around $3000 Hope this helps. Thanks Ajay, I recall you saying. I don't think that's an option in my council area and because we are at draft end panel stage I don't want to delay things. I have no doubt we could install a privacy screen ourselves (without louvres) for a few hundred bucks! My main worry on Friday was that they wouldn't remove the heat pump HWS when we signed off on the solar. It took a third opinion for them to agree to delete it. So I took that as a win and begrudgingly signed off on the privacy screen. I hope those are the last of the PCVs! Building Monte Carlo 40- Wisdom homes Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 6414Jun 17, 2017 9:36 pm I'm so sorry to hear about the issues you're having. I went through exactly the sane thing when I was building regarding privach screening to one side of the balcony to prevent overlooking (as if we would pop our heads over to look into the neighbours' yard!) Cost was $2100 from M for merbau leuvre screen similar size to yours - I lost the plot, they then halfed the price and I only agreed to prevent further delays with handover ... Good luck J My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: Building with Wisdom Homes 6415Jun 18, 2017 9:33 am Just wondering if anyone who's recently or close to finished have any pics of brickwork meeting the front door frame and window frames? Some of mine have pretty big gaps and I was curious as to how they would be finished. majestic35.weebly.com Re: Building with Wisdom Homes 6416Jun 18, 2017 9:57 am Rocchet Just wondering if anyone who's recently or close to finished have any pics of brickwork meeting the front door frame and window frames? Some of mine have pretty big gaps and I was curious as to how they would be finished. I'll have to check pics of the door frame area but I know over the window areas they will install the eaves on top of the brickwork. So during brickwork where they leaves gaps between the roofline and top of brickwork it does look strange, but it all works out once gutters and eaves are installed. Re: Building with Wisdom Homes 6417Jun 18, 2017 5:35 pm Rocchet Just wondering if anyone who's recently or close to finished have any pics of brickwork meeting the front door frame and window frames? Some of mine have pretty big gaps and I was curious as to how they would be finished. Hi Rocchet, gapa in windows are going to be covered by gyprock. With the doors, there will be frames added to it to cover. For the door this is done during lock up stage. Picture below: Door: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Window there is a metal that they put in to cover the gap done towards the end before Pci Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 6419Jun 18, 2017 7:26 pm ozmonkeyoy Washington29 ozmonkeyoy [quote="Washington29"]Hi guys, We recently submitted our landscaping plan but the developer came back requesting we put the fence set back past the stairwell (purple line). Meaning the laundry door would open onto the front side yard?! Crazy. W spoke to them and managed to gain approx 3.7m back to allow for the laundry door to access the rear yard (yellow line). We're still not happy though as it means the downstairs lounge window (which will be a spare bedroom) will open on to the street. Our original and ideal position was just behind the corner facade, but in front of the window. I'm going to call the developer today - but thought I'd see if anyone has any tips or advice before I do? We're so disappointed as one of the reasons we bought our corner block is because of the extra side yard we were getting. Thank you in advance!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hmmm, your developer seems to be acting pretty harsh, but I guess you need to find out why they are making that judgement. Do you have a pic of the site plan, showing your building envelope compared to the block. Are your building setbacks only the bare minimum required? There must be a reason why the developer is not allowing you to fence up to the side column. With ours (being a corner block), the developer allowed us to have the fence/gates right up against the corner treatment columns. Yeah it's bizarre! Here is our siting... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yes I can understand why you want the fence moved forward - its a bit of a wasted space in front of the fence. From the site plan, I can't see any reason why they wouldn't let you place the fence where you want it. Sight access from road shouldn't be an issue because its set back so much from your building line. Ours you can see below, and I actually want to move it now up to our front building line, because Wisdom have installed a tap to the front corner of the house, which I want to be in the backyard, but we'll see. I'm one of the last ones building in my estate, so I don't think the developer cares too much anymore, as other builds are getting away with a lot. Good luck with yours, definitely need to ask them why they want it set back so much. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote] Thanks Oz! Hopefully we can get it sorted asap. Building the Washington 29 with Wisdom Homes Re: Building with Wisdom Homes 6420Jun 18, 2017 7:26 pm MandM+4 Washington29 Hi guys, We recently submitted our landscaping plan but the developer came back requesting we put the fence set back past the stairwell (purple line). Meaning the laundry door would open onto the front side yard?! Crazy. W spoke to them and managed to gain approx 3.7m back to allow for the laundry door to access the rear yard (yellow line). We're still not happy though as it means the downstairs lounge window (which will be a spare bedroom) will open on to the street. Our original and ideal position was just behind the corner facade, but in front of the window. I'm going to call the developer today - but thought I'd see if anyone has any tips or advice before I do? We're so disappointed as one of the reasons we bought our corner block is because of the extra side yard we were getting. Thank you in advance!! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Best of luck! Unless it's in your design guidelines, it's very cheeky of them IMO, you paid for land you can't really use when you thought you could! Hopefully they come to the party. Thank you! 🤞🏼 Building the Washington 29 with Wisdom Homes Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18435 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73284 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8207 |
