Browse Forums General Discussion 1 Feb 20, 2009 10:14 pm We are very late 20's with 2 kids, wanting to invest in real estate and get of the working treadmill. Re: filling nail holes in walls 5Feb 23, 2009 7:54 pm We are very late 20's with 2 kids, wanting to invest in real estate and get of the working treadmill. Re: filling nail holes in walls 7Feb 24, 2009 12:55 am We are very late 20's with 2 kids, wanting to invest in real estate and get of the working treadmill. Re: filling nail holes in walls 8Feb 24, 2009 6:35 am Brad & Ree Asbestos??? You better believe it - more homes than not built in the Brisbane post war boom era feature significant use of asbestos. If you are in doubt get it checked - seriously. Cheers, Earl Re: filling nail holes in walls 9Feb 24, 2009 4:37 pm That aint no gyprock Better not sand it either.
I'll guarantee its asbestos. Dont be too concerned it just needs to be handled with some thought. Best bet will be to just scrape of the raised sections with a sharp chisel, fill the hole left and paint. Below are a couple of things that make handling small asbestos jobs less risky. Get your self a spray bottle and fill it with water. set it up to spray a light mist and keep the surface you are working on slightly damp. this will reduce the amount of dust and make cleaning up loose fibres much easier. Use a damp cloth to clean up any dust or chunks and when finished tie it up in a plastic bag and chuck it. Always seal any exposed asbestos straight away with paint. Dont drill, cut or sand. if you have to make any holes (like for new power point) use a screw driver to punch through it and pliers to break it out. Re: 11Apr 06, 2009 3:16 pm Brad & Ree wake_me Original post wars are generally smaller homes built on tight budgets and usually of a very basic no nonsense design as a result of the post war material shortages and high demand for housing to accomodate the countries new found desire to reproduce rapidly. They usually stood on concrete stumps and were constructed of hardwood frames lined with asbestos sheeting on the inside and either champher or weatherboard cladding externally (sometimes just more asbestos) That sounds about it! Asbestos??? I am renovating my house and there is asbestos in the wall. Houses built before 1983 in some form have asbestos. It needs to be removed properly, just too dangerous to do it yourself. One fibre can cause problems! The asbestos looks like a golf ball cover. I took this photo of mine, the dark bits are dust and cobwebs, I had to climb up on a chair to take it! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I hope this helps, and everything went well for you. Remember that not getting what you want is sometimes a wonderful stroke of luck! - Dalai Lama DIY, Home Maintenance & Repair Hi there, I just recently received my new house from my builder. We handed the house to another company to deal with the… 0 19046 Oh no! I would use a can of expandable foam ( there are some that will take render) then cut it back and render over the top 1 10230 ask the surveyor for clarification would be the logical approach 1 29240 |
