Browse Forums Owner Builder Forum Re: The Adventure Starts ! OB in Canberra on a small block 3Jun 01, 2017 11:05 pm Build thread http://tinyurl.com/llgc7yk Re: The Adventure Starts ! OB in Canberra on a small block 4Jun 02, 2017 9:38 am Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: The Adventure Starts ! OB in Canberra on a small block 13Jun 05, 2017 12:02 pm Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Re: The Adventure Starts ! OB in Canberra on a small block 19Jun 15, 2017 7:35 pm I would choose elevation. Not just for view, but also for things storm water drainage etc.. From the look of it, you cut and fill won't be too much... a guess would probably be something around the ~100mm off the back and ~300mm up from the 624 line.. Re: The Adventure Starts ! OB in Canberra on a small block 20Jun 22, 2017 8:12 pm Definitely going through with elevation if possible! At the moment I am looking through the single dwelling development code. Our block is supposed to be a medium density residential area (RZ4) According the the development code we are allowed (forced upon) 25sqm of private space area. I am arguing with the drafter at the moment as he thinks we need 36sqm (6x6m). I am crossing finger that we are right as the block is very narrow and with ~5x5m we would be able to put the private space on the side and push the courtyard setback all the way to the fence ! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wow I hadn't realised things had gotten that pricey in just a couple of years since I built, that is crazy with how much land is now costing if you aren't lucky enough to… 3 7136 Hi all, We are looking to build a new two storey house in western Sydney. Can anyone recommend a smallish builder to go with? We are trying to stay away from the big… 0 12158 consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6634 |
