Browse Forums Heating, Cooling & Insulation Re: How much emphasis should you put into your R Value? 2Mar 07, 2017 10:07 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: How much emphasis should you put into your R Value? 3Mar 07, 2017 11:06 pm Customised Burbank Indigo/Hawthorn in Officer VIC https://forum.homeone.com.au/viewtopic.p ... 2#p1680752 Re: How much emphasis should you put into your R Value? 5Mar 08, 2017 11:23 pm Customised Burbank Indigo/Hawthorn in Officer VIC https://forum.homeone.com.au/viewtopic.p ... 2#p1680752 Re: How much emphasis should you put into your R Value? 7May 30, 2017 10:15 pm bashworth probably the biggest change for me has been to limit the window sizes. This was a no cost change and increased my last house by almost a one star rating. For more check this link: Window Size Comparison Hi bashworth, Thanks for that link! Many new home designs have large glass areas that can open up to alfresco and back yards with a strong notion of open plan. In a 2 storey home, with lots of glass on the ground floor living area, is this counter intuitive? (Mutually exclusive) Trying to keep the house cool in summer and warm in winter? Re: How much emphasis should you put into your R Value? 8Jun 01, 2017 11:40 am Definitely worth the upgrade. Just about the cheapest bang for your buck to build a comfortable,energy efficient home. The other thing that's important, which you can often do for free, is orientate your house correctly. Choose a design with north facing living areas. It's called passive solar design. More can be found here, http://www.yourhome.gov.au/passive-design/orientation Re: How much emphasis should you put into your R Value? 9Jun 04, 2017 7:36 am Thanks, our block faces NE and length runs NW.
With insulated external walls and sound proofing selected internal one, would anyone 'upgrade their HVAC ducting to thicker INSULATED DUCTING'? Re: How much emphasis should you put into your R Value? 10Jun 05, 2017 11:34 pm GLO Thanks, our block faces NE and length runs NW. With insulated external walls and sound proofing selected internal one, would anyone 'upgrade their HVAC ducting to thicker INSULLATED DUCTING'? It depends on whether your ceiling space is insulated or ventilated. On a stinking hot day the heat in a ceiling would permeate into the ducts resulting in the system working harder to cool due to the warmer supply air. They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9660 As a tradesmen get a private inspector although I don't think there worth it in their profession themselves the reminder they serve to the tradesmen doing the work is… 3 27434 The last home I lived in didn't have a pool and when i went to sell it the agents were not happy, even telling me to put one in to sell the place. The agents weren't happy… 2 4302 |
