Browse Forums Lighting + Lighting Design Re: The downlight still gives off orange light even it is of 4May 26, 2017 11:20 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: The downlight still gives off orange light even it is of 5May 27, 2017 6:28 pm Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: The downlight still gives off orange light even it is of 6May 27, 2017 6:30 pm M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: The downlight still gives off orange light even it is of 7May 27, 2017 6:33 pm Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: The downlight still gives off orange light even it is of 10May 27, 2017 8:48 pm Muzza40 I bet you have Saturn switches with the blue led on them. Haha yes I do.... does this create the issue? C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: The downlight still gives off orange light even it is of 11May 27, 2017 9:30 pm I'm not saying it is definitely the problem but sometimes when you wire the blue light across the switch rather than with a neutral it allows some leakage through the light. This cam show up with l.e.d's just like what is happening. The lecky who did it should habe picked it up and fixed it if that is in fact the issue. Re: The downlight still gives off orange light even it is of 12May 28, 2017 8:37 am Muzza40 I'm not saying it is definitely the problem but sometimes when you wire the blue light across the switch rather than with a neutral it allows some leakage through the light. This cam show up with l.e.d's just like what is happening. The lecky who did it should habe picked it up and fixed it if that is in fact the issue. Good pickup - and yes that makes perfect sense. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Very common on rendered homes Smaller suppliers get the lower quality raw materials 6 11850 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11674 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17324 |
