Browse Forums Bathrooms and Laundry Re: What height shower rose? 4May 20, 2017 10:26 am If you increase the height of the shower head you might want to see that the screen height and tiling is also raised. On our standard plans the wall mounted shower rose is 1900mm high, screen is 2000mm high and tiling to 2100mm high. We will raise these a little as our ceilings will be higher than the standard 2440mm (so it looks proportional). Second Time 'Round Re: What height shower rose? 5Jun 03, 2017 8:34 am Our Build123 Hey Pat Around 2mtrs from the floor is a good height, so a bigger dropper closer the the 600mm would be best in my opinion. Regards James Mason http://www.renovationjunkies.com.au James you are the best Anyone built this plan before? Would be great to chat about it. Thank you. 0 29737 Correct. External the eaves will sit on top of the window frames, internally there will be 3 courses to the ceiling. Those details are from our house. We went with 28c… 5 10236 Slab needed a rebate. Better planning during design stage. Nothing can be done now without spending big $$$. 2 14397 |
