Hey All, hope all your builds are coming through smoothly!! Just wondering whether any of you had your valuations come in lower? Ours just came in 100k less!!!
Cheers
Browse Forums Building A New House Re: stage 19 - Aston - Craigieburn 50May 17, 2017 8:48 pm Hopefully you get better news this time. Worst case scenario you will have to pay LMI on the shortfall for the construction. (as per my scenario above) OR If you have an existing property with some equity, you could also access this through a top up on the existing loan and take the cash to the new property you building just to avoid the LMI. Good luck Building the Madison 40 | By Porter Davis Re: stage 19 - Aston - Craigieburn 51May 18, 2017 11:20 am Gio Hopefully you get better news this time. Worst case scenario you will have to pay LMI on the shortfall for the construction. (as per my scenario above) OR If you have an existing property with some equity, you could also access this through a top up on the existing loan and take the cash to the new property you building just to avoid the LMI. Good luck Thanks!!! Re: stage 19 - Aston - Craigieburn 53Jul 18, 2017 10:14 am Hi Aston 19, Congrats mate you guys must be very excited. Our build is reached completion of frame stage now in process of conducting inspections from a independent building inspector. Hopefully will be in before Christmas. Not unless you have managed to put it as a special condition into the contract somehow. 1 6154 The fastest thing a builder will do is bank your cheque, those systems work perfectly with lightning speed, everything else is slow burn. Just the way it is. 1 8706 1 4694 |
