Browse Forums Building A New House Re: M & C's First Build with HGWA - Eglinton 2Mar 29, 2017 12:22 am Follow our build with Express Two Storey (Ventura Group): viewtopic.php?f=31&t=85122 Re: M & C's First Build with HGWA - Eglinton 8Apr 10, 2017 1:17 am Follow our build with Express Two Storey (Ventura Group): viewtopic.php?f=31&t=85122 Re: M & C's First Build with HGWA - Eglinton 13Apr 12, 2017 7:52 pm Follow our build with Express Two Storey (Ventura Group): viewtopic.php?f=31&t=85122 Re: M & C's First Build with HGWA - Eglinton 18May 04, 2017 5:33 pm Imightbedave Plan looks really good to me! A few items which you could consider (and possibly already have!) - side access door from garage. Makes it easy to go from garage to laundry (perhaps a good entry for muddy shoes etc) and also means when landscaping etc you don't need to cart things down the right hand side and across the back and down again. You could also keep your bins down the left then rather than blocking your right side access. - Theatre doors - where will your tv, couches etc be located? Will the doors get in the way? Could move up or down if needed. - Recess at bottom of kitchen-depending what you'll use this for, it's a lot of space - could shorten in line with garage/hallway wall and make theatre wider in line with WIR below it (but possibly bring top wall down a bit too as the kitchen island bench is pretty close as it is!) Really though I quite like your design and given it's a 12.5 block you've still given yourself a heap of backyard without compromising on the house! Well done! Thanks for your suggestions, I didn't even think of the side access through the garage!! Will definitely add that to the list. The theatre doors will mostly remain closed when in use, and otherwise we will have one open. So hopefully it doesn't cause too much of an issue but will double check when buying furniture etc! The recess at the bottom of the kitchen was actually originally a study area, with a wall and a feature opening. We removed it from the plan as it was a dead space and we plan on using one of the bedrooms for a study. We are planning to put a sliding door in after handover, where that space is, so that bedroom 2 and the bathroom area can be closed off and used as a guest area, as we have family overseas who will come and visit, so it gives them a private area! We did plan to move the kitchen down to centralise it but decided on the sliding door idea, perhaps having some sort of storage there eventually too. Thanks for the feedback! We pushed the house as far forwards as it would go to give us a decent backyard area. So excited to see it come to life!! Re: M & C's First Build with HGWA - Eglinton 19May 04, 2017 5:35 pm m0llss Imightbedave Plan looks really good to me! A few items which you could consider (and possibly already have!) - side access door from garage. Makes it easy to go from garage to laundry (perhaps a good entry for muddy shoes etc) and also means when landscaping etc you don't need to cart things down the right hand side and across the back and down again. You could also keep your bins down the left then rather than blocking your right side access. - Theatre doors - where will your tv, couches etc be located? Will the doors get in the way? Could move up or down if needed. - Recess at bottom of kitchen-depending what you'll use this for, it's a lot of space - could shorten in line with garage/hallway wall and make theatre wider in line with WIR below it (but possibly bring top wall down a bit too as the kitchen island bench is pretty close as it is!) Really though I quite like your design and given it's a 12.5 block you've still given yourself a heap of backyard without compromising on the house! Well done! Thanks for your suggestions, I didn't even think of the side access through the garage!! Will definitely add that to the list. The theatre doors will mostly remain closed when in use, and otherwise we will have one open. So hopefully it doesn't cause too much of an issue but will double check when buying furniture etc! The recess at the bottom of the kitchen was actually originally a study area, with a wall and a feature opening. We removed it from the plan as it was a dead space and we plan on using one of the bedrooms for a study. We are planning to put a sliding door in after handover, where that space is, so that bedroom 2 and the bathroom area can be closed off and used as a guest area, as we have family overseas who will come and visit, so it gives them a private area! We did plan to move the kitchen down to centralise it but decided on the sliding door idea, perhaps having some sort of storage there eventually too. Thanks for the feedback! We pushed the house as far forwards as it would go to give us a decent backyard area. So excited to see it come to life!! Whoops - just realised you meant the other end of the kitchen, haha ! Study brain at the moment. We are possibly going to build a wine rack area there in the future, and want to leave it like that for storage to be built in as another possibility, as we don't have a large amount of storage areas built into the plan! hi guys. Please be nice. First time home builder in Qld. I would like some feedback please on whether I should build my granny flat first before my main house at the… 0 5037 So still no slab and apparently the concreter cancelled. Here come the delays... apparently things haven't recovered quite as much as I thought. I've been told maybe next… 8 32222 Thank you so much everyone. This all makes a lot of sense. I guess when you talk to a builder who butters up everything to look very polished, you get to start believing… 7 19328 |
