Browse Forums Building A New House Re: Building a Huntley 30 with Rawson @Colebee (Stone Cutter 117May 03, 2017 1:43 pm Another quick peak today, living room tiles done and splashback installed Cleaners were thier tidying up All scaffold and fence was being removed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building a Huntley 30 with Rawson @Colebee (Stone Cutter 118May 07, 2017 12:04 am Hi your house looks really great! Your block looked pretty flat? Why did they need to cut and drop garage by .5m? How much did it cost? How elevated was the front part of you land from st level? Ours is almost 1m high from road and then flattened out towards the back. We are also looking at greenway estate. Do you remember what was the soil class and salinity like? Re: Building a Huntley 30 with Rawson @Colebee (Stone Cutter 120May 08, 2017 8:13 pm faykis Hi your house looks really great! Your block looked pretty flat? Why did they need to cut and drop garage by .5m? How much did it cost? How elevated was the front part of you land from st level? Ours is almost 1m high from road and then flattened out towards the back. We are also looking at greenway estate. Do you remember what was the soil class and salinity like? Hi Faykis Slight incline i believe the cut out was around half a meter and land is around 1 meter above street level. We did need some drop edge beams across front of house but nothing significant dollar wise. Cant remember why garage was dropped but it didnt cost us extra Just started the Build process for Chifley 42 with Rawson homes, will keep you all posted with the Build progress. 0 2451 Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7496 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6709 |
