Browse Forums Building A New House Stockland Elara at Marsden Park 2306Apr 29, 2017 11:15 am 2.0 ARTICULATION ZONE/ENTRY FEATURE 2.1 An entry feature is to be incorporated into the design of your home. This can either be a portico/porch, verandah or deck. The entry feature must protrude forward from the main building line. @ladytwinklestar: Have you considered installing a deck instead? Re: Stockland Elara at Marsden Park 2307Apr 29, 2017 11:20 am kaycee 2.0 ARTICULATION ZONE/ENTRY FEATURE 2.1 An entry feature is to be incorporated into the design of your home. This can either be a portico/porch, verandah or deck. The entry feature must protrude forward from the main building line. @ladytwinklestar: Have you considered installing a deck instead? We had the same issue with our builder and I went straight to Stockland for clarification the way around it is either a deck or if your front facade protrudes the house you will be ok ... Our front facade has a pylon/coloum which sticks out this is enough Re: Stockland Elara at Marsden Park 2308Apr 29, 2017 11:20 am ladytwinklestar Hi All, does anyone of you have building plans where the porch doesn't need to protrude forward by 1m from building line? This is what has been specified in Elara design for Frontier release. I have seen many houses in Elara now that didn't follow this specs. I'm just wondering if I can do away with it as it will save us on building cost. Who is the builder Re: Stockland Elara at Marsden Park 2309Apr 29, 2017 11:26 am Greenway Village shopping centre to open at Marsden Park Have you all seen the streamers/banners that indicate where the planned shopping centre and playing field will be at Elara? Re: Stockland Elara at Marsden Park 2310Apr 29, 2017 8:58 pm gdmonty kaycee 2.0 ARTICULATION ZONE/ENTRY FEATURE 2.1 An entry feature is to be incorporated into the design of your home. This can either be a portico/porch, verandah or deck. The entry feature must protrude forward from the main building line. @ladytwinklestar: Have you considered installing a deck instead? We had the same issue with our builder and I went straight to Stockland for clarification the way around it is either a deck or if your front facade protrudes the house you will be ok ... Our front facade has a pylon/coloum which sticks out this is enough Hi gdmonty/kaycee, Does putting a decking will be cheaper than making the facade to protrude forward? I'm being charged by 4.8k for it. Thanks. Re: Stockland Elara at Marsden Park 2312Apr 29, 2017 9:18 pm kaycee @ladytwinklestar: A deck of 1m length should not cost $4.8. Include it in your plan and indicate to be done by owner. Thanks Kaycee. Re: Stockland Elara at Marsden Park 2313Apr 30, 2017 8:15 am kaycee Greenway Village shopping centre to open at Marsden Park Have you all seen the streamers/banners that indicate where the planned shopping centre and playing field will be at Elara? Playing fields' work is ongoing. It is next to St Lukes. I think the shopping centre is opposite the playing field but has no flyers on when it will be constructed. Re: Stockland Elara at Marsden Park 2314Apr 30, 2017 2:05 pm ladytwinklestar gdmonty kaycee 2.0 ARTICULATION ZONE/ENTRY FEATURE 2.1 An entry feature is to be incorporated into the design of your home. This can either be a portico/porch, verandah or deck. The entry feature must protrude forward from the main building line. @ladytwinklestar: Have you considered installing a deck instead? We had the same issue with our builder and I went straight to Stockland for clarification the way around it is either a deck or if your front facade protrudes the house you will be ok ... Our front facade has a pylon/coloum which sticks out this is enough Hi gdmonty/kaycee, Does putting a decking will be cheaper than making the facade to protrude forward? I'm being charged by 4.8k for it. Thanks. Which builder was this with Re: Stockland Elara at Marsden Park 2315Apr 30, 2017 2:20 pm gdmonty ladytwinklestar gdmonty [quote="kaycee"]2.0 ARTICULATION ZONE/ENTRY FEATURE 2.1 An entry feature is to be incorporated into the design of your home. This can either be a portico/porch, verandah or deck. The entry feature must protrude forward from the main building line. @ladytwinklestar: Have you considered installing a deck instead? We had the same issue with our builder and I went straight to Stockland for clarification the way around it is either a deck or if your front facade protrudes the house you will be ok ... Our front facade has a pylon/coloum which sticks out this is enough Hi gdmonty/kaycee, Does putting a decking will be cheaper than making the facade to protrude forward? I'm being charged by 4.8k for it. Thanks. Which builder was this with [/quote] Elderton Re: Stockland Elara at Marsden Park 2316Apr 30, 2017 4:44 pm Does anyone building with MJH at Elara? Any piece of advice/suggestions/feedback is welcome. Re: Stockland Elara at Marsden Park 2317May 01, 2017 10:08 am Is Stage 17 expected to register today? Any idea? Re: Stockland Elara at Marsden Park 2319May 01, 2017 11:12 am charan BuildThatThing Is Stage 17 expected to register today? Any idea? Yes, I got a call from Elara on Saturday saying my land from stage 17 will be registered today. Sweet! I don't think I will receive a call today as I have little mobile coverage at my workplace. |
