Browse Forums Building A New House Re: Firstyle Home - Braeside 42sq 29Apr 19, 2017 7:03 pm Starting the tender process with Firstyle for a Braeside 34. Can anyone confirm who the carpet and flooring suppliers is that they use? contemplating removing the flooring from the tender and doing after hand over. Thanks in Advance Re: Firstyle Home - Braeside 42sq 30Apr 19, 2017 7:13 pm Hay...abruzzo supplies tiling.. not sure abt the carpets..check with the sales guy..i m doing flooring after handover.. Re: Firstyle Home - Braeside 42sq 31Apr 20, 2017 9:21 am Hey wazzabrown4, they have a range of carpets to choose from when you head in for your internal colours appointment. It's pretty underwhelming to be honest so don't have high expectations. Re: Firstyle Home - Braeside 42sq 32Apr 20, 2017 12:25 pm Hay everyone...Does anyone know what is the approx cost for pouring a plain slab?? I am thinking to extend my Alfresco area by 4m x 3m. So interested to find out if it would be economical to go with the slab or decking after handover?? Re: Firstyle Home - Braeside 42sq 33Apr 24, 2017 6:00 am Finally the slab has been poured... is there anyway to tell if the builder has put the drop edge beams ?? I was charged 13k for the beams..also do guys think the slab is sitting too high from the first photo?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Firstyle Home - Braeside 42sq 35Apr 24, 2017 8:04 am Thanks Rocchet... I have compared the finish level of the slab with the two neighbors and I am the highest...I like the view though as we have got single story houses across the street... Re: Firstyle Home - Braeside 42sq 36Apr 24, 2017 12:57 pm Looks good Bhoot. At least you have a view now. Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Firstyle Home - Braeside 42sq 37Apr 24, 2017 1:18 pm Thanks Jordann - Can't wait to see the house completed... Re: Firstyle Home - Braeside 42sq 38May 04, 2017 3:41 pm Hay Everyone.. I need your help in understanding the following clause: "Floors to be grinded in lieu of screating for porcelain tiling" Is it better to go with grinded floors or screating?? I'll be doing the tiling after handover.. I prefer to go with porcelain tiles..but then I want to have the flexibility of installing ceramic as well... So which surface gives me more flexibility?? Cheers, M Firstyle Home - Braeside 42sq 39May 04, 2017 4:19 pm Its a waffle pod slab, reason why it is placed? my understanding is because they don't want the fill to be entire concrete, and would require more man hours and more concrete and expensive, plus drying so much concrete would take extra measures and extra time. So the waffle pods as its called, is used to fill the void that would require less concrete pouring and in circumstances, where the house is old and need to be demolished in so called future when it has had its time, the slab will be easy to remove. But your Garage and Alfresco in many cases is made of hard concrete to support the weight of cars or if you put a jack under the car so it doesn't poke hole in the floor, as the weight is concentrated on one point. I guess that will be enough for you to understand Aussie way of building, pretty much, not much effort is involved as in the past years like in europe all architecture is concrete and stones. Hi Kaiser85, We are building with Firstyle Homes. Our build has just started, slab pour is on Saturday (hopefully!). Their standard range is pretty good. We did our… 1 6475 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16263 From what I know about water tanks (I've been working with a client on them for a few years now) is this - The concrete can last a lifetime if they don't crack for some… 2 10629 |
