Browse Forums DIY, Home Maintenance & Repair Re: Crackling light switch 8Feb 19, 2009 7:28 am cheers Col Nation For information on caring for wool and other carpet and upholstery go to www.woolsafe.com.au Re: Crackling light switch 11Feb 19, 2009 4:02 pm Actually, guys we now no longer use it, for that very reason. Have notified the agent & let's see whether she gets it repaired.
This rental has so many things wrong with it or breaking down, yet we're paying a premium for it. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Crackling light switch 12Mar 02, 2009 8:07 pm Hi Southie ive recently had the same issue with my Garage light switch. crackling... at the switch
I have a new house. Awhile ago the electrician came out over another issue he said they had installed some faulty light switches.. The switches move. I now have to get him back to look at the garage light switch and the rest of the switches in the house. Re: Crackling light switch 14Mar 02, 2009 8:52 pm I had the same problem with my house two days ago. It's potentially dangerous but I was able to fix it.
I turned off the main switch (MAIN SWITCH at the power panel outside the house), unplugged the light switch, re-seated the wires properly then put them back again. It's working fine now. Legally, you need to use Electrician to do that for you Re: Crackling light switch 15Mar 05, 2009 1:22 am Quote: Legally, you need to use Electrician to do that for you Yes you do, because should you have troubles later with an electrical fault or fire anywhere in the house be prepared for the insurance company to scrub you IF they find out you have been monkeying with the wiring or switches. Call an electrician Arfur Re: Crackling light switch 16Apr 28, 2009 11:43 am We had a switch in the bathroom that did that. A sparky came out, pulled the switch apart and put it back together. He didn't even switch off the power to do it! All good ever since. Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1245 Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11813 That was always going to be a challenge and a test of patience. Full marks to your mate. Did you discuss the wet area near the trampoline? 16 17404 |
