Browse Forums Home Theatre & Automation Re: Home Technology Hub 381Feb 13, 2017 11:37 pm Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Home Technology Hub 392Apr 03, 2017 11:09 am hi, Check dolby website to get an idea on speaker placements.. buy 50/100 m 14 awg cable from Selby or similar and give the print out of the dolby set-up and the cables to the electrician if they are happy to do a cash job... Security cams/ door bells you need to have some idea on what you want.. it is easy to be misguided and spend money on things that don't fit your purpose... Camera position... if you are not sure.. ask then to run a cat6 from the camera control point to the roof space and leave enough cable on the roof space so you can take it to anywhere you want when you decide on the camera location (assuming you are going for a Power Over Ethernet (PoE) camera and don't need to run power separately) Hope it helps! Re: Home Technology Hub 393Apr 03, 2017 2:45 pm Speaker systems can be pretty complex. IMHO the best way to approach it is to decide exactly what equipment you will use, exactly where you will place it and work a plan from there. For example, I have a single receiver that is capable of multi room sound with 2 different sources. It is also a Dolby ATMOS capable receiver @9.2 channels but it can't do multiroom and ATMOS at the same time. For Audio advice I really like the guys at The Lifestyle Store in N Parramatta. Don't be afraid of the prices of their stuff, you can negotiate down for sure. I got a 40% off the rrp for a full set of Paradigms. You also need to think about subwoofer placement if you have a home theatre set up or even for just music. You can run RG6 from your audio source to wherever you want to put them. Re: Home Technology Hub 394Apr 04, 2017 11:06 pm Hi, has anyone got somfy motors for your blinds/curtains? If so, have you found a way to operate the blinds without using the somfy remote or mylink app? Thanks, Re: Home Technology Hub 395Apr 05, 2017 6:46 am RegVic Hi, has anyone got somfy motors for your blinds/curtains? If so, have you found a way to operate the blinds without using the somfy remote or mylink app? Thanks, I looked into this ages ago. Somfy does other wired solutions (admittedly I only found them on US websites) which you can wire into a normal light switch. You just need three mechs up, down and stop. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Home Technology Hub 397Apr 05, 2017 10:25 am Decided to go with Somfy thinking they are well known brand and will be easy to incorporate into the home automation eco system but I guess I am wrong... Somfy uses more proprietary stuff and not as easy to integrate as I thought... research continues.... Re: Home Technology Hub 399Apr 05, 2017 5:02 pm RegVic Decided to go with Somfy thinking they are well known brand and will be easy to incorporate into the home automation eco system but I guess I am wrong... Somfy uses more proprietary stuff and not as easy to integrate as I thought... research continues.... As mentioned by picto, depends on your HA system. Never worked with Somfy myself (yet, build prep in progress), however openHAB (my favourite HA system) has plugins specifically to work with Somfy Re: Home Technology Hub 400Apr 05, 2017 6:05 pm RegVic Decided to go with Somfy thinking they are well known brand and will be easy to incorporate into the home automation eco system but I guess I am wrong... Somfy uses more proprietary stuff and not as easy to integrate as I thought... research continues.... Just to clarify, the first motor can also be wired onto the digital output on a wired HA system ie cbus. So realistically you have a lot of different options... We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16915 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 111117 7 12193 |
