Browse Forums Heating, Cooling & Insulation Re: Ducted aircon after handover? Single story house 4Dec 01, 2010 2:46 pm 12 March 2010 - Land titles received 3 April 2010 - Signed building contract 14 April 2010 - Prestart 28 April 2010 - Loan approved 30 June 2010 - Slab completed 27 August 2010 - Brickwork completed 22 September 2010 - Roofing completed 30 September 2010 - Internal walls plastered 12 October 2010 - Lock Up 19 November 2010 - PCI 26 November 2010 - Handover 29 December 2010 - Moved In https://forum.homeone.com.au/viewtopic.php?f=31&t=32584 Re: Ducted aircon after handover? Single story house 8Mar 27, 2017 10:16 pm 594Jessica mdzzj We had our ducted cooling installed this week. 9 monthes after handover. We managed to get a better unit with more ducts for the same price quoted by the builder. Mess? The installers mopped and vacuumed Thanks! Now we will for sure not install the ducted ac when we build. Hi Jessica, I'm contemplating on whether to include Ducted AC in my package with Eden Brae Homes or not. They have quoted $11,614. Just wanted to check how did your ducted AC installation go after handover. I'm aware that this is an old thread but hoping to get some advice on which way to go. Also, is it a good idea to do downlights after handover as well? Please share your thoughts everyone. Kind Regards, VJ Re: Ducted aircon after handover? Single story house 9Apr 13, 2017 12:23 pm Generally you get considerably lower prices with down lights by doing after handover, and many do air con heating after as saving 10% and getting a better system are both realistic. Re: Ducted aircon after handover? Single story house 10Dec 02, 2017 10:06 am newey Check out air conditioning direct, buy a kit and save thousands. they also have a heap of videos on youtube on how to fit the ducting. I got a heap of quotes all around 12-14k, kit cost 5.5k, fitted the ducting myself, then got a air con man to fit the unit in the roof & do the electrical, cost another 1.8k Hope this helps Matt How easy is it to self-install most of it on a scale of 1-10? Are you quite handy already? I'm contemplating doing the same to save a few thousand and learn how it's done for future homes. Does the ducted A/C kit come with sufficient instructions? Clarendon Denton 24 | Gold Coast Status: Internal fitout! ETA: April 2018 Re: Ducted aircon after handover? Single story house 11Jan 30, 2018 1:01 pm Hi all, I'm planning to have a ducted reverse cycle A/c installed in my home (construction to start in June/July). The problem is, the builder provides gas ducted heating as a standard inclusion and is not willing to give me a rebate on that if I don't want that as they say that they are required to have heating included, else they wont get the building permit/certificate. I don't want to have ducted reverse cycle A/c installed via the builder as i'm sure they will add at least a 3k margin cost and I cant be sure about the quality of their work. If I choose to install after handover via a third party then I would have simply wasted money on having gas ducted heating included as part of the standard build only to have it removed later when installing ducted reverse cycle A/c. FYI, I plan to have an all electric home with no gas. Does anybody have a workaround for this issue? Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8636 We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4167 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15883 |
