Browse Forums Kitchen Corner Re: Difference between freestanding 90cm oven and built in 9 2Mar 22, 2017 6:26 am Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Difference between freestanding 90cm oven and built in 9 4Mar 22, 2017 9:17 am A 600 or 900mm built in oven is almost always 596mm high by the cabinet width. Retro fitting a new one is actually very easy if you stay with the standard sizes. Sure if you buy an oven with a non standard height then yes it will be hard but do let this be a reason for buying free standing. The best part of buying separate built in appliances is that your not limited to one brand and size. I have plenty of customers that have put in 600mm ovens with 700mm cooktops. You can mix and match brands and also gas or electricity. It gives you options. Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Difference between freestanding 90cm oven and built in 9 5Mar 22, 2017 2:40 pm Thanks for all the replies, Can you fit the same amount of dishes in the 90cm freestanding as the 90cm built in Re: Difference between freestanding 90cm oven and built in 9 7Mar 22, 2017 9:15 pm Berek Check out hardleynormal (I just did for you...) and it depends on the make and model. Inbuilt 90L FS 110L for one I checked. Thanks! Great ideaI might have to go in with my baking trays and see how many i can get in each one Difference between freestanding 90cm oven and built in 90cm 8Mar 22, 2017 9:41 pm It's interesting everyone has a preference I personally don't like free standing ovens and cooktop being together simply because if the salt or food scraps fall in between your stone and your kitchen bench are you going to pull the stove every time? I asked a close mate of mine recently who has one and he said he's moved in for 7 years but hasn't pulled it out once. I can't even begin to imagine the dirt or dead cockroaches underneath. That's why although my package comes with a free standing stove and oven I decided to split it. As well as that there are no gaps and is easy to clean and there is a kick board so I can't accidentally kick food on the ground underneath the free standing oven and cooktop. I rather have a low maintenance home where I can spend time with kids and family. But as I said everyone has a personal preference and I can certainly respect that. How often do I replace my cooktop or oven? I haven't had to as yet. But when the time comes sure will do it when I cross that bridge. Good luck Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au Re: Difference between freestanding 90cm oven and built in 9 9Mar 23, 2017 2:49 pm I 100% agree with wongbruce Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Difference between freestanding 90cm oven and built in 9 10Mar 23, 2017 5:55 pm I had a freestanding at my old house and food and oil definitely get stuck down the sides. We'll be going separate this time. In terms of capacity, it really depends on the make rather than built in vs freestanding. Re: Difference between freestanding 90cm oven and built in 9 11Apr 06, 2017 12:37 pm As was mentioned, capacity seems to be determined on individual make/model more than type. We had a freestanding 900mm stove in our last house. The gap on each side was minimal and I didn't have any issues with food going down. We also had the kickboard run across the bottom, so the legs were taken off and the whole thing sat on the base of the cabinets, which stopped anything getting under it (unlike the rental we are currently in). If you go freestanding make sure it will sit on the baseboard of the cabinets, not on the floor. FWIW, our next place will have built ins mainly because I'm wanting an induction cooktop and like the seamless look. Second Time 'Round Re: Difference between freestanding 90cm oven and built in 9 12Apr 10, 2017 3:32 pm First_Timer_Ray As was mentioned, capacity seems to be determined on individual make/model more than type. We had a freestanding 900mm stove in our last house. The gap on each side was minimal and I didn't have any issues with food going down. We also had the kickboard run across the bottom, so the legs were taken off and the whole thing sat on the base of the cabinets, which stopped anything getting under it (unlike the rental we are currently in). If you go freestanding make sure it will sit on the baseboard of the cabinets, not on the floor. FWIW, our next place will have built ins mainly because I'm wanting an induction cooktop and like the seamless look. I have seen and done many like this, you should see the grime and gunk that builds up ontop of the kickboard after ten years! Cutting Edge Kitchens and Cabinet Making http://cuttingedgekitchens.net.au http://www.facebook.com/pages/Cutting-Edge-Kitchens/290484196676 Mobile : 0419 430 575 PH: 9452 4772 Fax :9452 4772 cuttingedgekitchens@outlook.com Re: Difference between freestanding 90cm oven and built in 9 13Apr 19, 2017 4:21 pm CEK, I have read about people putting (squeezing) a strip of silicone down the small gap between benchtop and freestanding oven. Although I haven't seen it first hand. Have you seen this done and is it viable/worthwhile? Re: Difference between freestanding 90cm oven and built in 9 14Apr 19, 2017 11:36 pm jsmi CEK, I have read about people putting (squeezing) a strip of silicone down the small gap between benchtop and freestanding oven. Although I haven't seen it first hand. Have you seen this done and is it viable/worthwhile? I'm not sure how good this will look at all. For me having a beautiful kitchen is important because the kitchen for our new home will be the centrepiece. Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 10780 Bathroom renovation will likely include a back-to-corner bath and we’re considering a freestanding tap with hand-held shower such as the picture included. My hesitation… 0 24682 DIY, Home Maintenance & Repair Grind texture and paint off at blister up to top of fence Will see damp cement render 5 6257 |
