Browse Forums Home Theatre & Automation Re: Is "future proofing" a waste of money? 42Feb 18, 2009 11:24 am Stevep79 & Principessa Finished building Wisdom Homes Impression 33mkII in The Ponds, Sydney http://lilypadintheponds.blogspot.com Re: Is "future proofing" a waste of money? 44Feb 18, 2009 11:32 am Stevep79 & Principessa Finished building Wisdom Homes Impression 33mkII in The Ponds, Sydney http://lilypadintheponds.blogspot.com Re: Is "future proofing" a waste of money? 46Feb 18, 2009 11:58 am Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Is "future proofing" a waste of money? 48Feb 18, 2009 1:42 pm kiwi056 The key to all of this IMO is to have enough in the way of flexibility in your structured wiring, and to minimise the need for in some cases expensive point to point wiring. Bingo we have a winner even like i posted above having the holes pre drilled and pull wires cuts the retro fit cost in half... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Is "future proofing" a waste of money? 49Mar 11, 2009 11:07 pm hmm lots of random banter in here, i am geek. i spend lots of time on computers, as does my wife.
our plans are to put cat6 throughout the house, this is not just for uber speed gigabit connection! cat5/6 is known to some as the magic cable you can do alot of things with that preicous blue cable other than just stream movies from your vault in your panic room! just a couple of things you can do: move files (quickly/ securely and without interference) phone connection voip connection IP camera's Power (we use it for our wifi/ power over ethernet) audio and HDMI extending! yes there are good wireless routers coming out even with draft-N speed still doesn't have the security or the perfection of a cable. turn your laptop on next time your in the car outside the front of your house even you'll see how many wireless networks are out there. and, i simply wouldnt put a tv coax aerial port in each bedroom, its a good way to keep your family further and further away from you! cinema room/lounge/family room thats it. my $0.002 -Nathan 2nd-Fix | Blog Building with Desyn Homes previously with the insolvent [url=https://www.facebook.com/7NewsAdelaide/videos/1162546323776021/]Endeavour Homes[/url] Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20717 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16361 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7525 |
