Browse Forums Building A New House Re: North Shore Newhaven (Sydney) 81Feb 15, 2017 9:53 pm Build thread: Metricon Liberty 45 in Ryde, NSW Re: North Shore Newhaven (Sydney) 82Mar 06, 2017 10:50 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 84Mar 15, 2017 6:40 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 85Mar 15, 2017 8:55 pm Build thread: Metricon Liberty 45 in Ryde, NSW Re: North Shore Newhaven (Sydney) 86Mar 15, 2017 10:23 pm Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 87Mar 16, 2017 4:51 am Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 Re: North Shore Newhaven (Sydney) 88Mar 16, 2017 6:04 am Neville S I realised the height of the light switch the day after they installed the pre wiring. It was a bit of a debate with the wife but ended up leaving it at 1050mm. Reading this post again it brings up doubts. Oh well too late now. My Journey H1 thread | viewtopic.php?f=31&t=77665 Hi Nev, I'm sure it'll be fine. After a day or two you won't even notice I think. I'm real happy I made sure to meet the sparkies on site. I cringe thinking that i nearly didn't have the right pre wiring set up for the nbn which is already at my block. Hope your walk through goes ok today! If it's with NS, it'd be interesting to hear where he's off to next? I was told that the other SM named N who also works for M has left to go to Masterton, so they're 2 short in our area. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 89Mar 16, 2017 9:06 am nomnomnom Neville S I realised the height of the light switch the day after they installed the pre wiring. It was a bit of a debate with the wife but ended up leaving it at 1050mm. Reading this post again it brings up doubts. Oh well too late now. My Journey H1 thread | viewtopic.php?f=31&t=77665 Hi Nev, I'm sure it'll be fine. After a day or two you won't even notice I think. I'm real happy I made sure to meet the sparkies on site. I cringe thinking that i nearly didn't have the right pre wiring set up for the nbn which is already at my block. Hope your walk through goes ok today! If it's with NS, it'd be interesting to hear where he's off to next? I was told that the other SM named N who also works for M has left to go to Masterton, so they're 2 short in our area. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Agree I had to be onsite also for electrical and moved some things. SM rescheduled . Happy tilers were onsite last night Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 North Shore Newhaven (Sydney) 90Mar 18, 2017 10:54 pm So I went and had a look through the house today and the electrical job looks pretty good. I was really worried about the light switch being behind the door of Bedroom 2 (see below pic) but when I went to site today, clearly someone had some common sense and put it on the other side! Thankyou Vaccaro! In some areas the drilling was a little trigger happy as holes drilled in noggins made some look like a swiss cheese. I'm also a bit concerned that the aircon installers have put too few outlets in. Contract says up to 15 outlets will be installed but we only have maybe 10 in the house. I'm a bit puzzled. How do I confirm what the correct number should be? Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 91Mar 19, 2017 12:30 am Hi nom, good to see some progress. Didnt you get an electrical plan showing all the heating/cooling outlets? If not, maybe ask them to send you the plan. Re: North Shore Newhaven (Sydney) 92Mar 19, 2017 6:27 am In Melbourne in actually tells you and has different symbols for power points at different heights which it specifies. They don't have that in nsw? Re: North Shore Newhaven (Sydney) 93Mar 19, 2017 2:45 pm vuster Hi nom, good to see some progress. Didnt you get an electrical plan showing all the heating/cooling outlets? If not, maybe ask them to send you the plan. They don't give us a plan like that in NSW AFAIK. In the contract it states placement of outlets at the disgression of their air con contractor. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 94Mar 19, 2017 2:47 pm emmyawards In Melbourne in actually tells you and has different symbols for power points at different heights which it specifies. They don't have that in nsw? All powerpoints are installed 110mm from FFL from memory. The pic above shows the power points and the light switches, and fans and light locations etc. It doesn't show where the aircon outlets go though. Only the aircon return. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 95Mar 21, 2017 3:31 pm nomnomnom vuster Hi nom, good to see some progress. Didnt you get an electrical plan showing all the heating/cooling outlets? If not, maybe ask them to send you the plan. They don't give us a plan like that in NSW AFAIK. In the contract it states placement of outlets at the disgression of their air con contractor. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092[/quote Yep, I remember asking the electricals consultant about placement of outlets and she mentioned upto the a/c guy installing, and we could see if they will accomodate our wishes on the placement (don't want it above the beds) North Shore Newhaven (Sydney) 96Mar 24, 2017 11:54 pm Spotme nomnomnom vuster Hi nom, good to see some progress. Didnt you get an electrical plan showing all the heating/cooling outlets? If not, maybe ask them to send you the plan. They don't give us a plan like that in NSW AFAIK. In the contract it states placement of outlets at the disgression of their air con contractor. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092[/quote Yep, I remember asking the electricals consultant about placement of outlets and she mentioned upto the a/c guy installing, and we could see if they will accomodate our wishes on the placement (don't want it above the beds) In the contract it states up to 15 air con outlets. In mine, there are maybe only 10 max. Has anyone had any luck in getting a credit for the unused balance? If it was one or two I probably wouldn't mind but this is one third so .... Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 97Jun 08, 2017 12:13 am Yay! we have a front door, internal stairs and internal doors, architraves and skirting. Plus cabinetry installed too! Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - http://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 98Jun 08, 2017 12:50 am Looks fantastic Nom! Is there some extra backboard where the rangehood will go? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: North Shore Newhaven (Sydney) 99Jun 08, 2017 1:45 am Quirmeball1280 Looks fantastic Nom! Is there some extra backboard where the rangehood will go? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Well spotted, yeah I forgot all about it. When we had our appointment with Kitchen culture, they suggested a back board as it will stop discolouration from grease etc. Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build Thread - http://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Cheers Nom Newhaven 36 by M Blog - North Shore Newhaven (http://nsnewhaven.blogspot.com.au) Build - https://forum.homeone.com.au/viewtopic.php?f=31&t=85092 Re: North Shore Newhaven (Sydney) 100Jun 08, 2017 7:28 am Looking great! Starting to feel like a home there The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18204 Hi, can anyone recommend a custom home builder who can build in north east area? Looking to build a custom 4-br energy-efficient home with a max budget of 750k. If they… 0 22826 May I ask why you chose not to use GJ Gardiner? I'm actually meeting with one of the sales guys tomorrow for an appointment. Definitely not signing anything yet… 3 13262 |
