Browse Forums Owner Builder Forum Re: Perth NOR OB on 5 Acres - Kitchen and Pool :-) 1583Dec 06, 2016 7:12 pm Build thread http://tinyurl.com/llgc7yk Re: Perth NOR OB on 5 Acres - Kitchen and Pool :-) 1586Jan 07, 2017 5:43 am Build thread http://tinyurl.com/llgc7yk Re: Perth NOR OB on 5 Acres - Kitchen and Pool :-) 1590Mar 12, 2017 10:23 am Looks great, you've done a great job on it Build thread http://tinyurl.com/llgc7yk Re: Perth NOR OB on 5 Acres - Kitchen and Pool :-) 1592Mar 13, 2017 10:10 pm Thanks Guys hopefully will be polished and sealed this week <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Perth NOR OB on 5 Acres - Kitchen and Pool :-) 1593Mar 17, 2017 7:21 pm Sanding has commenced Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Perth NOR OB on 5 Acres - Kitchen and Pool :-) 1598Mar 17, 2017 10:02 pm Thanks WG but I know your's will be fantastic. Regarding the lines it's just trying to work with what we have......luckily at the last minute we had an engineer come out and reengineer the roof to remove the poles and then out roof carpenter tweaked it a little bit more. We are back working with tradies we've worked with before and I'm always eager to take on board and advice <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Perth NOR OB on 5 Acres - Kitchen and Pool :-) 1599Mar 17, 2017 10:03 pm Looks great! Can't wait to see the floor finished Build thread http://tinyurl.com/llgc7yk Re: Perth NOR OB on 5 Acres - Kitchen and Pool :-) 1600Mar 18, 2017 2:48 pm Beautiful flooring! Owner Builders in boot-shaped Yorke Peninsula : viewtopic.php?f=38&t=80264& Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3645 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 9871 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11731 |
