Browse Forums Pools & Spas Re: Swimming Pool construction in Sydney prior building cons 2Mar 10, 2017 6:42 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Swimming Pool construction in Sydney prior building cons 4Mar 12, 2017 9:41 am bashworth I recently posted about this on my blog at : Swimming Pool Thanks Bassworth! Very informative blog!! Looks like I need to build the pool first but need to make sure the building architects gives us the right measurement/ height etc! Its a biy risky I feel. But no other option if we go for a narrow block!! Re: Swimming Pool construction in Sydney prior building cons 5Mar 12, 2017 10:30 am MandM+4 We are putting a pool in before our build but our land has literally just registered so we haven't finalised it all yet. We have been advised to put in a separate DA for the pool as putting it in with the house can cause issues with BASIX ratings. You don't need a pool plan before the tender, but youd need to have a rough idea of size and where you want to put it. Within a certain proximity to the house the builder would put extra piering in (2.5m for our builder), so ours will be just over 2.5m from the house as we have plenty of space. The pool requires a hard cover during the house build which the pool builder will add to your quote. A lot of pool builders are having promotions at this time of year so this time next year would be a good time to lock it in, if you get some pool quotes around the time you go for tender you will get emails with promos at the end of summer We had the initial work on our pool completed before our build started and would echo MandM's suggestions. A separate building permit (applied for by the pool builder) was issued for the pool. A few other suggestions. Make sure that the cover your builder is quoting will be solid enough to be acceptable to your builder. Some pool builders install very flimsy covers and your house builder may ask for a more substantial one in that case. In our case, because the pool was dug (and concrete poured) prior to site cut, we had to arrange a separate earlier set-out of the rear of the house by our builder so that the pool position and levels could be worked out accurately. So make sure you quiz your builder closely with respect to the order that work will happen and whether they will do site cut before or after the pool goes in. You also need to talk to your pool builder early about the plumbing and electrical requirements so that your house builder makes the necessary provisions in your plans. Hope that helps. Re: Swimming Pool construction in Sydney prior building cons 6Mar 14, 2017 5:27 pm We do quiet a few pools prior to building . A few tips -you need to come to agreement with your builder before you sign a contract. Pool generally needs to be at least 1.5m away from house . As stated getting the height correct can be difficulties is getting boundary marks when there are no fences . We have had a builder mark out a incorrect datum height . Lucky for us we had the builder sign a set out sheet before we installed pool. The other problem with the height is the building contract allows for up to 100mm height variation . Do the maths and get quotes for before and after house . If you aren't saving min $5000 I would recommend you do it after build . As for approval it depends if you need a da or can do a complying development (cdc) . If you can do it, But you do need to show the approved house plans to Certifier . As for builder doing gas and power connections for the pool . If you have signed a contact they will sting you to do them .if not negotiate a price . If you have a alfresco area adjoining pool area its best not to have it tiled in the building contract . Have it done by the same tiler/ landscaper who does around the pool. It will better blend pool to house . Re: Swimming Pool construction in Sydney prior building cons 7Mar 18, 2017 10:01 pm wheeliworks We do quiet a few pools prior to building . A few tips -you need to come to agreement with your builder before you sign a contract. Pool generally needs to be at least 1.5m away from house . As stated getting the height correct can be difficulties is getting boundary marks when there are no fences . We have had a builder mark out a incorrect datum height . Lucky for us we had the builder sign a set out sheet before we installed pool. The other problem with the height is the building contract allows for up to 100mm height variation . Do the maths and get quotes for before and after house . If you aren't saving min $5000 I would recommend you do it after build . As for approval it depends if you need a da or can do a complying development (cdc) . If you can do it, But you do need to show the approved house plans to Certifier . As for builder doing gas and power connections for the pool . If you have signed a contact they will sting you to do them .if not negotiate a price . If you have a alfresco area adjoining pool area its best not to have it tiled in the building contract . Have it done by the same tiler/ landscaper who does around the pool. It will better blend pool to house . Thanks for your valuable tips wheeliworks. Unfortunately our block is a narrow block (12.5m frontage through out). So we'll need the pool built early as there wont be any access later. Its gonna be most costly now i guess, hardcover cost+ delay in building to start, delay in pool da approval = loss and loss ? The last home I lived in didn't have a pool and when i went to sell it the agents were not happy, even telling me to put one in to sell the place. The agents weren't happy… 2 4239 Thanks again Simeon for being so elaborate. Appreciate it. Its gives us a very idea. Kind Regards 4 3665 |
