Browse Forums General Discussion Re: How many data points did you put in? 8Apr 04, 2016 11:05 pm Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Re: How many data points did you put in? 12Mar 12, 2017 6:56 am Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 Re: How many data points did you put in? 17Mar 12, 2017 9:14 am Yeah it's overkill and I do have UniFi WiFi, but I didn't want to be limited in the future, and the cost was only about $40 per point for me. Re: How many data points did you put in? 18Mar 12, 2017 6:22 pm sajidmib Good Work .. did you use patch panel in rack or cables running direct into switch, if i m planning to do the termination of Cat 6 into patch panel would that cost me extra money Also I got netgear prosafe 16 port Non POE as the security camera runs of DVR and are poe anyways. what else u reckon to neat up the whole set up Yes I used a 12RU 19" rack with a patch panel, and the NBN equipment is mounted at the rear of the rack. Keeps everything neat and central. Funny thing is I only use one of the outlets. I patched directly from the NBN NTD to one of the outlets behind the TV and put the modem router there. The TV, XBox and Bluray player is plugged in to the LAN ports on the routet and everything else in our house (around 15 devices) are all wifi. Everything works great. Building Services Engineer Renovating our 1960's modernist home in Brisbane https://forum.homeone.com.au/viewtopic.php?f=53&t=82091 If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13928 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20815 0 12086 |
