Browse Forums Renovation + Home Improvement Re: Apartment Bathroom Renovation 9Mar 04, 2017 8:26 pm kitty1 Thanka for the info. The tile stripper trades said they normally just remove the tiles and shower base leaving the cement floor which they would sand down to ready for tilers to tile over again. I was hoping then to tile the entire bathroom floor and use the tiles as a shower base making it look more up to date. I hope that is all possible. Should be ok, talk with a tiler to double check. Only issue would be if they originally waterproofed ontop of the screed which they can sometimes do. Kind Regards James Mason - Our Build. www.renovationjunkies.com.au www.ourbuildhandyman.com.au I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10064 This is a very tight fit, I'm not sure if you'll be able to achieve what you've described. Would you consider accessing the separate toilet from the laundry? If so maybe… 1 11304 Hello Josh, This is Irving from PRIMA, we are a manufacturer of the staircase, railings, kitchen cabinets, windows, doors from China. If you have requirement to purchase… 0 5473 |
