Browse Forums General Discussion Re: Demolition recommendation 2Feb 16, 2017 5:41 pm Our build thread viewtopic.php?f=31&t=82369&p=1525857&hilit=fairhaven#p1525857 Re: Demolition recommendation 4Feb 17, 2017 6:40 pm Our build thread viewtopic.php?f=31&t=82369&p=1525857&hilit=fairhaven#p1525857 Re: Demolition recommendation 6Feb 20, 2017 3:52 pm So you are removing the asbestos yourself? Are you licensed to do so? Have you made allowances in YOUR costings for insurance,running costs of a 30 plus ton excavator & dump truck for 3-4 days, demolition permit, independent asbestos inspection/certification & certificate that states all asbestos has been removed from site. Do the quotes include removal of concrete slabs/driveway, foundations & footings to 1m below ground level, trees shrubs & site scrape? If your sub $15K quotes cover all of the above and you have done due diligence on the contractor & checked reviews by previous clients, then good luck to you. Let us know how it turns out. Our build thread viewtopic.php?f=31&t=82369&p=1525857&hilit=fairhaven#p1525857 Re: Demolition recommendation 7Mar 06, 2017 8:35 am Old Bloke So you are removing the asbestos yourself? Are you licensed to do so? Have you made allowances in YOUR costings for insurance,running costs of a 30 plus ton excavator & dump truck for 3-4 days, demolition permit, independent asbestos inspection/certification & certificate that states all asbestos has been removed from site. Do the quotes include removal of concrete slabs/driveway, foundations & footings to 1m below ground level, trees shrubs & site scrape? If your sub $15K quotes cover all of the above and you have done due diligence on the contractor & checked reviews by previous clients, then good luck to you. Let us know how it turns out. Thanks Old Bloke Not doing asbestos ourselves but had quotes for the following services to be done independently and segmented from the full demo: Asbestos removal $3k Trees $2k Speaking to a few more demo people and more tips, the following became clear By incorporating the asbestos and tree removal into the demo work they are both cheaper A semi trailer load is approx $1500 not $150 We have approx 6 semi trailers worth So costs are as follows $9k for waste including soil, trees and building materials $1.5k for asbestos fees $0k for tree removal - is part of tip fees in the majority Wages $1k So total cost just under $12k Add in profit for owner $2k Total cost is $14k plus GST. I've received quotes in this vicinity from 3 different companies since my last post, one will do $13.5k + as he wants to recycle some materials. All reputable All licenced All insured All provided references So in the end, came in under $15k albeit not by much but is not some amateur operation as you were eluding to. We have engaged a guy who runs a salvage yard and I've spoken to builders and independents he has worked with. Old Bloke So you are removing the asbestos yourself? Are you licensed to do so? Have you made allowances in YOUR costings for insurance,running costs of a 30 plus ton excavator & dump truck for 3-4 days, demolition permit, independent asbestos inspection/certification & certificate that states all asbestos has been removed from site. Do the quotes include removal of concrete slabs/driveway, foundations & footings to 1m below ground level, trees shrubs & site scrape? If your sub $15K quotes cover all of the above and you have done due diligence on the contractor & checked reviews by previous clients, then good luck to you. Let us know how it turns out. Re: Demolition recommendation 8Mar 06, 2017 12:27 pm Plus GST = $15,400 The figures I was quoting were inclusive of GST. Our build thread viewtopic.php?f=31&t=82369&p=1525857&hilit=fairhaven#p1525857 Re: Demolition recommendation 10Mar 06, 2017 2:45 pm I skipped over the $13.5k part so I stand corrected. If you've found someone that reasonably priced & good you'll have to share the details. Our build thread viewtopic.php?f=31&t=82369&p=1525857&hilit=fairhaven#p1525857 Re: Demolition recommendation 11Mar 06, 2017 9:04 pm Wow anyone working on less than 20% profit margin running all that heavy equipment is not going to be in business for long... I think when they say they will recycling all the materials that's code for bury it on a mate's farm somewhere 😂 I'm with Old Bloke on this one, make sure they do a complete job and remove all old house footings and services from below the ground level. Good luck! Kind Regards James Mason - Our Build. www.renovationjunkies.com.au www.ourbuildhandyman.com.au Re: Demolition recommendation 13Mar 07, 2017 7:12 am I am with our build 123 on this one, make sure they remove old footings and restore the site. What about site drainage? They could ruin your site if water does not drain properly post demolition. Also you have a problem with someone driving 200 k + range rover but there is another angle, maybe it's because he is good at what he does, I have not seen losers doing that. And yes I have seen a major development site shut down because demolishers left asbestos strewn all over it.(and not until I have seen a fencer with his young two sons working on it oblivious to the asbestos danger. Regardless, if you are doing the demolition, you are the first builder on the site, act like one. That means: permit, planning, communication, supervision, control. If you trip, a second builder could come out with hefty variations. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Demolition recommendation 14Mar 15, 2017 8:16 am I was quotes $12K-$16K for demolition. that's after paying $3000 for removal of asbestos from the eaves front and rear porch ceilings. I've managed to reduce this more by doing a lot of work myself. I gave away half the roof tiles for free (advertised on Gumtree) and had a Second hand building materials place come and removed all the timber windows, fittings and a few other things at no cost. I've also arranged for them to come back and collect the timber roof trusses again at no cost to me as long as I remove them and place them close to the driveway to make it easier for them to load it on the truck. They'll also come back and remove the timber floorboards. As for the bricks, I'll be reusing them. It would cost be 75 cents per brick to buy commons plus what ever the cost would be to remove them. They're lime mortar so clean easily and I have a few guys helping to clean them. I know this is not the fastest way to build but I can afford the extra time it will take, especially if it means saving $$$ to spend elsewhere. Re: Demolition recommendation 15May 12, 2017 5:40 pm How did you get on with your demolition and which company did you end up engaging? Our build thread viewtopic.php?f=31&t=82369&p=1525857&hilit=fairhaven#p1525857 Re: Demolition recommendation 16May 13, 2017 10:20 am Old Bloke How did you get on with your demolition and which company did you end up engaging? Onspot demolitions Completed for $13k Did a good job, builder even made them dig up a couple of areas as evidence footings are gone, which they were Just needed some shopping around and some deep analysis on the pricing modelling, profitability etc - which is what I do for a living Trees removed with no damage to fence, block levelled and all rubbish removed Re: Demolition recommendation 17May 13, 2017 10:44 am That's a great price - well done. Who are you building with? Our build thread viewtopic.php?f=31&t=82369&p=1525857&hilit=fairhaven#p1525857 Re: Demolition recommendation 18May 13, 2017 11:15 am Old Bloke That's a great price - well done. Who are you building with? Cheers I'm managing project Just got a family member who's an architect builder and is helping me out along the way Win-win relationship thus far Re: Demolition recommendation 19Jun 18, 2017 6:39 pm How's your build going? Have you started a thread? Our build thread viewtopic.php?f=31&t=82369&p=1525857&hilit=fairhaven#p1525857 We had this happen to us last year and got charged a variation. Try and give away as much as you can that is usable to charity otherwise if you are in Sydney I have a… 1 4508 We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13759 If you need to pay for a project manager you would be well advised to just engage a builder who would take full responsibility for the build. As opposed to you OB where… 5 15090 |
