Browse Forums Building A New House Re: Building at Willowdale 2876Feb 17, 2017 4:52 pm Has anyone considered getting an independent inspector to walk through their build at all stages, or at least considered one for the final walk through? If so, which option? Any thoughts/comments/suggestions/recommendations? Re: Building at Willowdale 2877Feb 17, 2017 6:18 pm ![]() Has anyone considered getting an independent inspector to walk through their build at all stages, or at least considered one for the final walk through? If so, which option? Any thoughts/comments/suggestions/recommendations? We are planning on getting an inspector - I've seen HK Ryan and Houspect recommended quite a bit on the forum. One of them offers a discount if you mention the forum but I forget which one. We are planning on getting a pre linings inspection where they will check frame, brickwork, roof, electrical then a PCI inspection. Our builder only allows 2 inspections but I've read those two are sufficient. I just want the peace of mind that an expert has checked it over. Re: Building at Willowdale 2878Feb 18, 2017 8:22 am ![]() ![]() Has anyone considered getting an independent inspector to walk through their build at all stages, or at least considered one for the final walk through? If so, which option? Any thoughts/comments/suggestions/recommendations? We are planning on getting an inspector - I've seen HK Ryan and Houspect recommended quite a bit on the forum. One of them offers a discount if you mention the forum but I forget which one. We are planning on getting a pre linings inspection where they will check frame, brickwork, roof, electrical then a PCI inspection. Our builder only allows 2 inspections but I've read those two are sufficient. I just want the peace of mind that an expert has checked it over. Ditto; as well as wet area inspections at waterproofing stage (before tiling) by a specific waterproofing inspector. They have all the tools to check the thickness & appropriate type of waterproofing has been used etc, as well as the clout to report & recommend if it isn't to AStandard. All the best with it guys Re: Building at Willowdale 2879Feb 18, 2017 10:08 am ![]() ![]() ![]() Has anyone considered getting an independent inspector to walk through their build at all stages, or at least considered one for the final walk through? If so, which option? Any thoughts/comments/suggestions/recommendations? We are planning on getting an inspector - I've seen HK Ryan and Houspect recommended quite a bit on the forum. One of them offers a discount if you mention the forum but I forget which one. We are planning on getting a pre linings inspection where they will check frame, brickwork, roof, electrical then a PCI inspection. Our builder only allows 2 inspections but I've read those two are sufficient. I just want the peace of mind that an expert has checked it over. Ditto; as well as wet area inspections at waterproofing stage (before tiling) by a specific waterproofing inspector. They have all the tools to check the thickness & appropriate type of waterproofing has been used etc, as well as the clout to report & recommend if it isn't to AStandard. All the best with it guys Great tip. Thanks guys. Re: Building at Willowdale 2880Feb 18, 2017 9:46 pm Hi people, was hoping you could help me decide regarding insulation under Colorbond Roof. The builder is offering SARKING & R4 GLASSWOOL BATTS to the ceiling; however they've suggested installing the ANTICON blanket as well at extra cost. Could you please advise if ANTICON blanket is required along with R4 GLASSWOOL BATT & SARKING? Has anybody installed the ANTICON blanket under their colorbond roof? Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 22262 Following these simple steps will help you mitigate unwanted costs, have your expectations met and give… 0 4975 ![]() you need to understand the breakdown of warranties. 90 warranty is considered as minor defects rectification period where as the longer ones are more major/structural… 1 5880 |
