Browse Forums Pools & Spas Re: Distance between pool, house and boundary 4Feb 05, 2017 1:02 pm Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Distance between pool, house and boundary 6Feb 05, 2017 2:59 pm Building Casaview Denison 30 https://fortdenison.wordpress.com/about Re: Distance between pool, house and boundary 7Feb 05, 2017 3:13 pm If it is still being built they will have a sign out the front of their house with builder and certifier details . You should ring the certifier . If it is complete you can ring the council' Re: Distance between pool, house and boundary 8Mar 12, 2017 7:20 am xyz I am a little bit worrying about my neighbours who put their pool quite close to the boundary. 80cm to the to-be water line. Blacktown council (NSW). Is it legal? I'll take a guess here. If you are able to measure that it's 80cm, then they might be allowing 15-20cm concrete wall and tiling. It's only a guess Good luck Found the answer. The recommended distance is .... 1 4584 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 12631 ask the surveyor for clarification would be the logical approach 1 15967 |
